Covox
bill
Hello, i had an idea, that is probably stupid, but i wanted to tell you :
It's about generating sounds (digital waveforms) thanks to MIOS.
I allready read somewhere on the ucappps website, on maybe it was on this forum that it's possible to generate sounds, but i cant remember the way it's working.
You probably know the good old covox 'soundcards'
http://en.wikipedia.org/wiki/Covox
Dont you think it could be very funny to generate 8bit waveforms thanks to this, and a DOUT module ? (but maybe it's not fast enough ?)
It could be possible to store loads of 8bit (even 4bit !!) waveforms inside a pic, or even to write algorithm for sound generation  ::)
So, what do you think ?
Link to comment
Share on other sites
Is this what you're getting at??
Yep, that was the idea, i guess a pic can do it, but what about mios ?
then what do you think about the covox dac ?
(maybe it's too shitty, and a real dac do the job better, for quite the same price)
Link to comment
Hi Bill
Stupid me, :-[
http://ucapps.de/mios/analog_toolbox_v1_1c.zip do it better ...
Can someone explain me what the analog toolbox do ? (i dont have a AOUT interface to try it)
The analog toolbox is made to generate analog control voltages
for modular synth modules (like analog filters, voltages...)
it stores a 8 bit sine wavetable for converting a saw->sine (see map.c)
About that Covox DAC, have you seen:
http://www.ucapps.de/mbhp_aout_lc.html
What do you think of a avrsyn for sound generation
and a mios engine for modulation, presets,control surface...
:D
bye,
Michaël
Link to comment
Well, it could be a cool project, but that's not the kind of stuff i'm looking after, but maybe avrsyn can be a good base to start from, if it's open source.
I'd like to do a 4bit waveform generator (like the gameboy wave channel)
That produce a very typical sound, that i love so much !! (amigaish sounding ;)
Link to comment
I think that all the code for this is allready in the analog toolbox code,
it uses the same waveform generation technique as the avrsyn
only avrsyn is written in asm and it has a 24bit fasor (better frequency resolution)
right now the analog toolbox lfo is updated each millisecond
so max output frequency is 1000/2 = 500Hz
don't know how high you could set the update freq  ???
// initialize the timer - it should be invoked each mS
  MIOS_TIMER_Init(0, 10000); // 1 mS / 100 nS = 10000 cycles
so suppose the highest note you need is 2kHz, you will need 4kHz
-> 1/4000 = 0.25mS
-> 0.25mS/100nS = 2500 cycles
-> MIOS_TIMER_Init(0,2500);
do you think this is correct?
Do you have an example of that sound?
I'm too young to know how an amiga sounds  :)
Link to comment
Amigaish waveforms that i'm talking about can be heard in that lo-bat tune : http://www.lo-bat.be/muziek/good_morning.mp3
Software is musicline, a dynamic softsynth/tracker on the amiga. http://www.musicline.org/
For the gameboy, listen to this tune http://sidabitball.free.fr//NewSlip.mp3
At 1'00, the bass sound is the 4bit wav, then it change to a kind of distorted guitar ;)
Atm, it's just an idea and i'm just not sure it's possible, but i cant stop to think about it  :P
Link to comment
Guest
Reply to this topic...
