bosone Posted March 24, 2003 Posted March 24, 2003 after hearing my sid at work i wonder:how do you deal witha "stereo sid"? ok, lets suppose i build another core+sid module, and then? i think the only thing to do is connecting both unit to the same midi in and then "play them together" with the same patch. should the two SID produce slightly different sounds for a "stereo" effetc?other ideas?
TK. Posted March 25, 2003 Posted March 25, 2003 Hi Matteo,I've prepared an example which should demonstrate the possibilities. When you look for synthesizers today, you will notice that mostly the audio routine is the same: Oscillators -> Filters -> (EQs) -> Stereo spread -> EffectsThe SID provides oscillators and filters, but everything else has to be attached after the Audio out in order to improve the sound (some years ago this was the common way, most synths only provided some cheap and useless effects...)So, easiest way is to use a sequencer like Cubase or Logic, open the Audio In, attach some VST effects and activate the live playing mode :)Here a comparison:http://members.tripod.de/ucapps/midibox_sid/mbsid_demo9_1.mp3This well known tune from a C64 game is played only with a MIDIbox SID and some EQ improvements.http://members.tripod.de/ucapps/midibox_sid/mbsid_demo9_2.mp3Here two slightly detuned MIDIbox SID are playing. It doesn't really sound interestinghttp://members.tripod.de/ucapps/midibox_sid/mbsid_demo9_3.mp3and here a Stereo Delay has been inserted into the audio path. Do you hear the difference? ;-)And the last example should show, that MIDIbox SID is not far from a Virus when you just add an chorus effect. In this example, three MIDIbox SID are played with the "Cool Brass" preset over the same MIDI channel. The oscillators of the first SID are not detuned, the second is transposed by -12, the third by +12http://members.tripod.de/ucapps/midibox_sid/mbsid_demo9_4.mp3Have fun w/ VST! ;-)Best Regards, Thorsten.
pezkall Posted March 29, 2003 Posted March 29, 2003 Is there any possibility of adding MIDI controlled effects to my work-in-progress mbSID? This would be ultimate. I'm mostly thinking of delay and chorus, much like in the above samples.
TK. Posted March 29, 2003 Posted March 29, 2003 Hi Pezkall,an AOUT interface to external effect gear (also Moog filter, etc), accessible via Control Matrix and CC, is planned. :)Best Regards, Thorsten.
pezkall Posted March 29, 2003 Posted March 29, 2003 Doesn't get any better than that, does it? :)Great!
bosone Posted March 31, 2003 Author Posted March 31, 2003 Hi Pezkall,an AOUT interface to external effect gear (also Moog filter, etc), accessible via Control Matrix and CC, is planned. :)ehi... what do you mean!?!?!? do you have in mind an analogue/digital multiFX unit!??!?!?!?!?!?!?
jerash Posted April 2, 2003 Posted April 2, 2003 Hi Pezkall,an AOUT interface to external effect gear (also Moog filter, etc), accessible via Control Matrix and CC, is planned. :)Best Regards, Thorsten.AOUT could drive CV inputs, is it the game ?
TK. Posted April 2, 2003 Posted April 2, 2003 yes... like it can be found on the SID intro page since 6 months ;-)Best Regards, Thorsten.
bosone Posted April 2, 2003 Author Posted April 2, 2003 i didn't understood well what was the matter!!!i'm impatient to know something more! ;D
