hi,
could someone explain me why when compiling my app i get this error in many file:
"processor type not defined"
  • Replies 106
  • Created
  • Last Reply
Top Posters In This Topic
It's not what you'd expect either.... The processor does seem to be defined in the source... I'm looking at it now...
i've re-do all the work from scratch, and the only error i get now are:
.objs\aout.asm:598:Error [103] syntax error
.objs\aout.asm:600:Error [113] Symbol not previously defined (reg).
.objs\aout.asm:600:Error [113] Symbol not previously defined (bit).
.objs\aout.asm:605:Error [145] Unmatched ENDM.
.objs\aout.asm:606:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:607:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:608:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:609:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:610:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:611:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:612:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:613:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:614:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:615:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:616:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:617:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:618:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:619:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:620:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:621:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
any suggestion?
Warning - while you were typing a new reply has been posted. You may wish to review your post.
Hah, I just figured it out too :D ROFL...That's 3 hours wasted! ;)
Hey mail me the new one and I'll scope it out.
i've tried to integrate the code you give me,
now i just get this two errors:
Compiling: aout.c
aout.c:267:19: warning: no newline at end of file
aout.c:185: syntax error: token -> 'void' ; column 10
what is wrong?
this one is pretty easy: just make a new line at the end of the file, so that the file does not end with a char but a blank line!
could you post a snippet (maybe lines 180 to 190) of aout.c?
cheers,
AC
thanks  i've solved this first errors.
now i get this one:
aout.c:213: syntax error: token -> '' ; column 0
Process terminated with status 1 (0 minutes, 1 seconds)
1 errors, 0 warnings
here is a quote of the 4 last line of my file:
210:      bcf    CV_AOUT_LC_LAT_RCLK, CV_AOUT_LC_PIN_RCLK ; release latch
211:endasm;
213;  }
214:
Hi moxi,
I think you have to add two underscores before calling
[tt]__asm
asmcontent...bla...
__endasm;[/tt]
best,
Michael
btw: is it normal that there's line 212 missing or have I watched too much doctor who investigating dissapearing things ;D
oups! it's me that forgot it!
now, with the underscores before asm and endasm:
syntax error: token -> '__endasm' ; column 8
here is my file in this last state, i've added all the code needed (i think):
#include "cmios.h"
#include "pic18f452.h"
#include "main.h"
#include "aout.h"
// Global variables
// AOUT values
unsigned int aout_value[8];
// stores the last AOUT values (to determine, if the shift registers have to be updated)
unsigned int last_aout_value[8];
// the gate pins
aout_gates_t aout_gates;
// last state of the aout gate flags to determine changes
aout_gates_t last_aout_gates;
// This function initializes the AOUT module
void CV_AOUT_LC_Init(void) {
__asm
;; enable pin drivers
bcf CV_AOUT_LC_TRIS_RCLK, CV_AOUT_LC_PIN_RCLK
bcf CV_AOUT_LC_TRIS_DOUT, CV_AOUT_LC_PIN_DOUT
bcf CV_AOUT_LC_TRIS_SCLK, CV_AOUT_LC_PIN_SCLK
;; set voltages to 0V
lfsr FSR0, AOUT0_L
movlw 8
movwf MIOS_PARAMETER3 ; used as loop counter here
CV_AOUT_LC_InitVoutLoop
clrf POSTINC0
movlw 0x80
movwf POSTINC0
decfsz MIOS_PARAMETER3, F
rgoto CV_AOUT_LC_InitVoutLoop
;; update the AOUT pins
rcall CV_AOUT_LC_Update
return
__endasm;
void CV_AOUT_LC_Load2SR(void) {
    __asm
        bcf    CV_AOUT_LC_LAT_SCLK, CV_AOUT_LC_PIN_SCLK ; clear clock
;; superfast transfer with unrolled loop (takes some memory, but guarantees the
;; lowest system load :)
CV_AOUT_LC_WRITE_BIT MACRO reg, bit
bcf CV_AOUT_LC_LAT_DOUT, CV_AOUT_LC_PIN_DOUT ; set out pin depending on register content (reg.bit)
btfsc reg, bit
bsf CV_AOUT_LC_LAT_DOUT, CV_AOUT_LC_PIN_DOUT
nop
        bsf    CV_AOUT_LC_LAT_SCLK, CV_AOUT_LC_PIN_SCLK ; rising clock edge
        bcf    CV_AOUT_LC_LAT_SCLK, CV_AOUT_LC_PIN_SCLK ; falling clock edge
ENDM
CV_AOUT_LC_WRITE_BIT TMP1, 7
CV_AOUT_LC_WRITE_BIT TMP1, 6
CV_AOUT_LC_WRITE_BIT TMP1, 5
CV_AOUT_LC_WRITE_BIT TMP1, 4
CV_AOUT_LC_WRITE_BIT TMP1, 3
CV_AOUT_LC_WRITE_BIT TMP1, 2
CV_AOUT_LC_WRITE_BIT TMP1, 1
CV_AOUT_LC_WRITE_BIT TMP1, 0
CV_AOUT_LC_WRITE_BIT TMP2, 7
CV_AOUT_LC_WRITE_BIT TMP2, 6
CV_AOUT_LC_WRITE_BIT TMP2, 5
CV_AOUT_LC_WRITE_BIT TMP2, 4
CV_AOUT_LC_WRITE_BIT TMP2, 3
CV_AOUT_LC_WRITE_BIT TMP2, 2
CV_AOUT_LC_WRITE_BIT TMP2, 1
CV_AOUT_LC_WRITE_BIT TMP2, 0
;; this must be done once all SRs in the chain have been uploaded!
#if 0
        bsf    CV_AOUT_LC_LAT_RCLK, CV_AOUT_LC_PIN_RCLK ; latch SID values
bcf CV_AOUT_LC_LAT_DOUT, CV_AOUT_LC_PIN_DOUT ; clear out pin (standby)
#endif
__endasm;
void CV_AOUT_LC_LoadAOUTx_8_8(void)
__asm
;; 8bit/8bit
swapf PREINC1, W ; AOUT0_H[3:0] -> TMP2[7:4]
andlw 0xf0
movwf TMP2
movf POSTDEC1, W ; AOUT0_L
swapf INDF1, W ; AOUT0_L[7:4] -> TMP2[3:0]
andlw 0x0f
iorwf TMP2, F
movf POSTINC1, W ; AOUT0_H
movf POSTINC1, W ; AOUT1_L
swapf PREINC1, W ; AOUT1_H[3:0] -> TMP1[7:4]
andlw 0xf0
movwf TMP1
movf POSTDEC1, W ; AOUT1_L
swapf INDF1, W ; AOUT1_L[7:4] -> TMP1[3:0]
andlw 0x0f
iorwf TMP1, F
bsf POSTINC1, 7 ; AOUT1_H
movf POSTDEC1, W ; AOUT0_H
bsf INDF1, 7 ; AOUT0_H
rgoto _CV_AOUT_LC_Load2SR
__endasm;
//  FUNCTION: CV_AOUT_LC_Update
//  DESCRIPTION: refreshes the AOUT pins if AOUT values have been changed
//  OUT:  -
//  USES: TMP[12345] and MIOS_PARAMETER[12]
void CV_AOUT_LC_Update(void) {
__asm
;; check if any output has to be updated
IFCLR AOUT0_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT1_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT2_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT3_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT4_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT5_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT6_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT7_H, 7, rgoto CV_AOUT_LC_Update_SRs
rgoto _CV_AOUT_LC_Update_NoSRs
__endasm;
void CV_AOUT_LC_Update_SRs(void) {
__asm
lfsr FSR1, AOUT6_L ; loads AOUT6_[LH] and AOUT7_[LH]
rcall CV_AOUT_LC_LoadAOUTx_8_8
lfsr FSR1, AOUT4_L ; loads AOUT4_[LH] and AOUT5_[LH]
lfsr FSR1, AOUT2_L ; loads AOUT2_[LH] and AOUT3_[LH]
lfsr FSR1, AOUT0_L ; loads AOUT0_[LH] and AOUT1_[LH]
rcall _CV_AOUT_LC_LoadAOUTx_8_8
__endasm;
i've added properly the __asm and endasm; for each parts...now the reports tell me that a lot of symbol are not defined (MIOS_PARAMETER3,POSTINC0,INDF1...)it's like the asm code was not integrated correctly... :(
as the snippet has just 193 lines, I expect the error has been before...
let's see what looks suspicious:
- line 54: you should move the [tt]return[/tt] after the [tt]__endasm; [/tt]==>
[tt]__endasm;
return;
}[/tt]
- line 93: [tt]#if 0[/tt]
if 0 will never be true and therefore will never be processed? is that okay?
in cases like these, there might be an error in the header file?
besides the "return;" I can see no syntax error.
[tt]MIOS_PARAMETER3[/tt] is declared in cmios.h wich is included correctly. let's see if that [tt]return; [/tt]solves it...
there is only header text before, this is the full file..
your hint don't solve the problems, here is a quote of the errors reports:
.objs\aout.asm:216:Error [108] Illegal Character (,)
.objs\aout.asm:216:Error [128] Missing argument(s).
.objs\aout.asm:217:Error [113] Symbol not previously defined (CV_AOUT_LC_LoadAOUTx_8_8).
.objs\aout.asm:218:Error [108] Illegal Character (,)
.objs\aout.asm:218:Error [128] Missing argument(s).
.objs\aout.asm:219:Error [113] Symbol not previously defined (CV_AOUT_LC_LoadAOUTx_8_8).
.objs\aout.asm:220:Error [108] Illegal Character (,)
.objs\aout.asm:220:Error [128] Missing argument(s).
.objs\aout.asm:221:Error [113] Symbol not previously defined (CV_AOUT_LC_LoadAOUTx_8_8).
.objs\aout.asm:222:Error [108] Illegal Character (,)
.objs\aout.asm:222:Error [128] Missing argument(s).
.objs\aout.asm:224:Error [128] Missing argument(s).
.objs\aout.asm:225:Error [128] Missing argument(s).
.objs\aout.asm:226:Error [128] Missing argument(s).
.objs\aout.asm:237:Error [103] syntax error
.objs\aout.asm:238:Error [103] syntax error
.objs\aout.asm:239:Error [103] syntax error
.objs\aout.asm:240:Error [103] syntax error
.objs\aout.asm:241:Error [103] syntax error
.objs\aout.asm:242:Error [103] syntax error
.objs\aout.asm:243:Error [103] syntax error
.objs\aout.asm:244:Error [103] syntax error
.objs\aout.asm:245:Error [174] Unknown opcode "rgoto"
.objs\aout.asm:256:Warning [203] Found opcode in column 1.
.objs\aout.asm:257:Error [103] syntax error
.objs\aout.asm:260:Error [113] Symbol not previously defined (TMP2).
.objs\aout.asm:262:Warning [203] Found opcode in column 1.
.objs\aout.asm:262:Error [113] Symbol not previously defined (INDF1).
.objs\aout.asm:263:Error [103] syntax error
.objs\aout.asm:266:Error [113] Symbol not previously defined (TMP2).
.objs\aout.asm:267:Error [113] Symbol not previously defined (POSTINC1).
.objs\aout.asm:268:Error [113] Symbol not previously defined (POSTINC1).
.objs\aout.asm:269:Warning [203] Found opcode in column 1.
.objs\aout.asm:270:Error [103] syntax error
.objs\aout.asm:273:Error [113] Symbol not previously defined (TMP1).
pic16_allocRegByName:963 symbol name _aout_value regop= 00000000
.objs\aout.asm:275:Warning [203] Found opcode in column 1.
pic16_allocRegByName:963 symbol name _last_aout_value regop= 00000000
.objs\aout.asm:275:Error [113] Symbol not previously defined (INDF1).
pic16_allocRegByName:963 symbol name _aout_gates regop= 00000000
pic16_allocRegByName:963 symbol name _last_aout_gates regop= 00000000
.objs\aout.asm:276:Error [103] syntax error
.objs\aout.asm:279:Error [113] Symbol not previously defined (TMP1).
.objs\aout.asm:280:Error [113] Symbol not previously defined (POSTINC1).
.objs\aout.asm:283:Error [113] Symbol not previously defined (INDF1).
.objs\aout.asm:285:Error [174] Unknown opcode "rgoto"
.objs\aout.asm:295:Error [128] Missing argument(s).
.objs\aout.asm:298:Error [103] syntax error
.objs\aout.asm:299:Error [128] Missing argument(s).
.objs\aout.asm:300:Error [113] Symbol not previously defined (reg).
.objs\aout.asm:300:Error [113] Symbol not previously defined (bit).
.objs\aout.asm:301:Error [128] Missing argument(s).
.objs\aout.asm:303:Error [128] Missing argument(s).
.objs\aout.asm:304:Error [128] Missing argument(s).
.objs\aout.asm:305:Error [145] Unmatched ENDM.
.objs\aout.asm:306:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:307:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:308:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:309:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:310:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:311:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:312:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:313:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:314:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:315:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:316:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:317:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:318:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:319:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:320:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:321:Error [174] Unknown opcode "CV_AOUT_LC_WRITE_BIT"
.objs\aout.asm:323:Error [128] Missing argument(s).
.objs\aout.asm:324:Error [128] Missing argument(s).
.objs\aout.asm:325:Error [128] Missing argument(s).
.objs\aout.asm:336:Error [128] Missing argument(s).
.objs\aout.asm:337:Error [128] Missing argument(s).
.objs\aout.asm:338:Error [128] Missing argument(s).
.objs\aout.asm:340:Error [108] Illegal Character (,)
.objs\aout.asm:340:Error [128] Missing argument(s).
.objs\aout.asm:342:Error [113] Symbol not previously defined (MIOS_PARAMETER3).
.objs\aout.asm:343:Error [174] Unknown opcode "CV_AOUT_LC_InitVoutLoop"
.objs\aout.asm:344:Error [113] Symbol not previously defined (POSTINC0).
.objs\aout.asm:346:Error [113] Symbol not previously defined (POSTINC0).
.objs\aout.asm:347:Error [113] Symbol not previously defined (MIOS_PARAMETER3).
.objs\aout.asm:348:Error [174] Unknown opcode "rgoto"
.objs\aout.asm:350:Error [113] Symbol not previously defined (CV_AOUT_LC_Update).
where have I to define this symbols?
Moxi,
you just have to care about the very first errors. Most time the rest of the errors are a result of the first one.
An illegal character is reported right before CV_AOUT_LC_LoadAOUTx_8_8, if I count these line-numbers (113) up to 108, this brings us straight to your "#if 0" thing.
please remove this completely from the code and compile again:
#if 0
#endif
When I think about it, it seems very likely that C-preprocessor directors are not supported in ASM codesnippets!
I bet this is it!
I tried to build this on my system.  It appears that the error is
occurring here:
[tt]
[/tt]
There is no preprocessor definition for AOUT6_L as far as I can see.
It's in aout.h but in a section the is ifdef'd out.  Am I off base here?
have you created a proper makefile?
you must open MAKEFILE.SPEC in an editor and add this line right below l:39 (MK_SET_OBJ pic18f452.c main.c)
[tt]MK_ADD_OBJ aout.c[/tt]
more entries if you have more files like aout.c...
then save and open up your console (DOS promt or terminal)
change directory to the /tools dir and call
[tt]mkmk.pl (path to MAKEFILE.SPEC here)[/tt]
then you should see this output:
[tt]Makefile generated.
Makefile.bat generated.[/tt]
then call [tt]make[/tt] from the directory of your sources.
I could compile these files without any error:
[tt]Block 003000-0033FF allocated - Checksum: 16
Block 003400-0037FF allocated - Checksum: 60[/tt]
good point, but I just discovered a tiny "#endif", so this should be alright...
as it did indeed compile on my computer, I think moxi forgot to add aout.c to the makefile, so there's some important stuff missing for the compiler or linker or whatever...
but these #if 0 parts seem indeed a bit cheesy to me... and if they compile, yet they don't seem to improve readability... just my 2c...
cheers ,)
Michael
that's done, but still the same errors reports.
i've triedto just include the two file in the skeleton with no success too (same report)
then it must either be a misconfiguration in your code::blocks IDE or some errors in one of the other files (main.h, main.c ...)
I could also take a look into the other files if you made it available ;)
