TK. Posted August 6, 2006 Posted August 6, 2006 Propably because you toggle the SCLK two times within the loop?In addition, it makes sense to insert a NOP or another instruction between the toggle as well in order to add some delay for a proper pulseBest Regards, Thorsten.
moxi Posted August 6, 2006 Author Posted August 6, 2006 it's good, i've removed the second bsf CV_AOUT_LC_LAT_SCLK, CV_AOUT_LC_PIN_SCLK ; rising clock edge MOVED FOR AOUT_LC DRIVER bcf CV_AOUT_LC_LAT_SCLK, CV_AOUT_LC_PIN_SCLK ; falling clock edgefrom your code and that works..1 get the right pattern for the two values...
moxi Posted August 6, 2006 Author Posted August 6, 2006 ...no sorry, it's from the code i give you.. :-Xthanks
stryd_one Posted August 7, 2006 Posted August 7, 2006 it's goodWoo!!! ;DI'm sure we all learned a lot - I know I did! :)
moxi Posted August 7, 2006 Author Posted August 7, 2006 :), thanks again for your hint TK.now the code is working for my four cv output:the define in aout.h:#if 1 //common AOUT_LC connections#define AOUT_LC_LAT_RCLK _LATC // The latch enable input#define AOUT_LC_TRIS_RCLK _TRISC //is connected to Port C.5#define AOUT_LC_PIN_RCLK 5 // (CANNOT be shared with other outputs!)#define AOUT_LC_LAT_DOUT _LATC // The data pin#define AOUT_LC_TRIS_DOUT _TRISC //is connected to Port C.4#define AOUT_LC_PIN_DOUT 4 //(can be shared with other outputs)#define AOUT_LC_LAT_SCLK _LATD // The shift clock input pin SCLK#define AOUT_LC_TRIS_SCLK _TRISD // is connected to Port D.5#define AOUT_LC_PIN_SCLK 5 //(can be shared with other outputs)#endifthe new code for the file aout.c:/* * AOUT_LC program module * This module is contains a lot of assembler-optimized code for fastest execution * * ========================================================================== * * Copyright © 2005 Thorsten Klose (tk@midibox.org) * * ========================================================================== * * This file is part of a MIOS application * * This application is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or * (at your option) any later version. * * This application is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with This application; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA * * ========================================================================== *//////////////////////////////////////////////////////////////////////////////// Include files/////////////////////////////////////////////////////////////////////////////#include "cmios.h"#include "pic18f452.h"#include "main.h"#include "aout.h"/////////////////////////////////////////////////////////////////////////////// Global variables/////////////////////////////////////////////////////////////////////////////// AOUT valuesunsigned int aout_value[8];// stores the last AOUT values (to determine, if the shift registers have to be updated)unsigned int last_aout_value[8];// the gate pinsaout_gates_t aout_gates;// last state of the aout gate flags to determine changesaout_gates_t last_aout_gates;/////////////////////////////////////////////////////////////////////////////// This function initializes the AOUT module/////////////////////////////////////////////////////////////////////////////void AOUT_Init(void){ unsigned char i; // Enable pin drivers__asm ;; since the pins are defined in assembler-friendly syntax (-> aout.h) ;; we have to clear the pins within an ASM block bcf AOUT_LC_TRIS_RCLK, AOUT_LC_PIN_RCLK bcf AOUT_LC_TRIS_DOUT, AOUT_LC_PIN_DOUT bcf AOUT_LC_TRIS_RCLK, AOUT_LC_PIN_SCLK__endasm; // clear gate pins and request update aout_gates.ALL = 0x00; last_aout_gates.ALL = 0xff; // set AOUT voltages to 0V and request update for(i=0; i<sizeof(aout_value); ++i) { aout_value = 0x0000; last_aout_value = 0xffff; }}/////////////////////////////////////////////////////////////////////////////// This is an internal assembler function which updates four chained// 74HC595 devices/////////////////////////////////////////////////////////////////////////////// following variables are placed outside the function (instead of making them static)// to simplify the addressing within an assembler blockunsigned char loop_ctr; // loop counterunsigned int aout_sr0; // chain dataunsigned int aout_sr1;void AOUT_Load2SR(unsigned int sr0_value, unsigned int sr1_value){ aout_sr0 = sr0_value; aout_sr1 = sr1_value;__asm bcf AOUT_LC_LAT_SCLK, AOUT_LC_PIN_SCLK ; clear clock COPIED FROM MBCV DRIVER ;; bcf AOUT_LAT_CS, AOUT_PIN_CS ; activate chip select NOT NEEDED FOR AOUT_LC ;; I believe that the below might be able to be ignored for the AOUT_LC? ;; you will notice that the instructions are sometimes arranged ;; in a special order to ensure proper output signals - for example: ;; between a rising and a falling SCLK edge there is at least one ;; other instruction to ensure that the high pulse of the SCLK ;; is longer than 100 nS (the MAX525 datasheet specifies at least 40 nS) banksel _loop_ctr movlw 32 ; init loop counter FOR 2 AOUT_LC modules movwf _loop_ctr, 1 ;; This is the same as the original AOUT driver with the names changed, and the latching copied from the MBCVAOUT_Load2SR_Loop: banksel _aout_sr0 bcf AOUT_LC_LAT_DOUT, AOUT_LC_PIN_DOUT ; set DOUT depending on current MSB btfsc _aout_sr1+1, 7, 1 bsf AOUT_LC_LAT_DOUT, AOUT_LC_PIN_DOUT rlcf _aout_sr0+0, F, 1 ; start to shift the 16-bit value rlcf _aout_sr0+1, F, 1 ; second step for the 16-bit shift rlcf _aout_sr1+0, F, 1 ; third step for the 16-bit shift rlcf _aout_sr1+1, F, 1 ; last step for the 16-bit shift bsf AOUT_LC_LAT_SCLK, AOUT_LC_PIN_SCLK ; rising clock edge MOVED FOR AOUT_LC DRIVER nop ;; not sure it's the right place, but that works bcf AOUT_LC_LAT_SCLK, AOUT_LC_PIN_SCLK ; falling clock edge banksel _loop_ctr decfsz _loop_ctr, F, 1 ; loop 32 times bra AOUT_Load2SR_Loop bsf AOUT_LC_LAT_RCLK, AOUT_LC_PIN_RCLK ; latch SID values bcf AOUT_LC_LAT_DOUT, AOUT_LC_PIN_DOUT ; clear out pin (standby) bcf AOUT_LC_LAT_RCLK, AOUT_LC_PIN_RCLK ; release latch__endasm;}/////////////////////////////////////////////////////////////////////////////// This function should be called from USER_Tick() to update the requested// AOUT pins/////////////////////////////////////////////////////////////////////////////void AOUT_Update(void){ if( (aout_value[0] != last_aout_value[0]) || (aout_value[2] != last_aout_value[2]) ) { AOUT_Load2SR(aout_value[0] | (0x3000) | (0xff00), aout_value[2] | (0x3000) | (0xff00)); last_aout_value[0] = aout_value[0]; last_aout_value[2] = aout_value[2];} if( (aout_value[1] != last_aout_value[1]) || (aout_value[3] != last_aout_value[3]) ) { AOUT_Load2SR(aout_value[1] << 8 | (0x3000) | (0xff), aout_value[3] <<8 | (0x3000) | (0xff)); last_aout_value[1] = aout_value[1]; last_aout_value[3] = aout_value[3];}}AOUT Update of the gate is missing, as i won't use them.my two aout_lc modules are set in 8/8bit configuration, my map.c file is configured to load 8 bit value in aout_value[x] :example, for my first CV: /////////////////////////////////////////////////////////////////////////// // AOUT #1: forward CC7 of MIDI channel #1 aout_value[0] = CONV_7BIT_TO_8BIT(midi_cc_chn0[7]);there is probably useless code in the AOUT_Update function...but i've make it working doing a lot of hardware testing, and as i'm a beginner ,i'm not sure that i understood all things fine...thanks you all..
TK. Posted August 7, 2006 Posted August 7, 2006 There is still room for improvements. ;-)You can remove the channel selection (OR combination with 0x3000), otherwise you will get wrong results on Channel 2 and 4 (or 1 and 3? don't know). In addition, since 32 bits are transfered with one run, you have to arrange the 8bit values in the following way:void AOUT_Update(void){ if( aout_value[0] != last_aout_value[0] || aout_value[1] != last_aout_value[1] || aout_value[2] != last_aout_value[2] || aout_value[3] != last_aout_value[3] ) { AOUT_Load2SR(((aout_value[1]&0xff) << 8) | (aout_value[0]&0xff), ((aout_value[3]&0xff) << 8) | (aout_value[2]&0xff)); last_aout_value[0] = aout_value[0]; last_aout_value[1] = aout_value[1]; last_aout_value[2] = aout_value[2]; last_aout_value[3] = aout_value[3]; }}[/code]otherwise the second Load2SR will overwrite the values of the first.Best Regards, Thorsten.
moxi Posted August 7, 2006 Author Posted August 7, 2006 You can remove the channel selection (OR combination with 0x3000), otherwise you will get wrong results on Channel 2 and 4 (or 1 and 3? don't know).it's exactly why i've tested many bit manipulation!i will try this tonight...your code is more clear!
