Propably because you toggle the SCLK two times within the loop?
In addition, it makes sense to insert a NOP or another instruction between the toggle as well in order to add some delay for a proper pulse
  • Replies 106
  • Created
  • Last Reply
Top Posters In This Topic
it's good, i've removed the second
  bsf  CV_AOUT_LC_LAT_SCLK, CV_AOUT_LC_PIN_SCLK  ; rising clock edge  MOVED FOR AOUT_LC DRIVER
  bcf  CV_AOUT_LC_LAT_SCLK, CV_AOUT_LC_PIN_SCLK  ; falling clock edge
from your code and that works..
1 get the right pattern for the two values...
thanks again for your hint TK.
now the code is working for my four cv output:
the define in aout.h:
#if 1
//common AOUT_LC connections
#define AOUT_LC_LAT_RCLK     _LATC // The latch enable input
#define AOUT_LC_TRIS_RCLK _TRISC //is connected to Port C.5
#define AOUT_LC_PIN_RCLK     5 // (CANNOT be shared with other outputs!)
#define AOUT_LC_LAT_DOUT     _LATC // The data pin
#define AOUT_LC_TRIS_DOUT _TRISC //is connected to Port C.4
#define AOUT_LC_PIN_DOUT     4 //(can be shared with other outputs)
#define AOUT_LC_LAT_SCLK     _LATD // The shift clock input pin SCLK
#define AOUT_LC_TRIS_SCLK _TRISD // is connected to Port D.5
#define AOUT_LC_PIN_SCLK     5 //(can be shared with other outputs)
#endif
the new code for the file aout.c:
* AOUT_LC program module
* This module is contains a lot of assembler-optimized code for fastest execution
* Copyright © 2005  Thorsten Klose (tk@midibox.org)
* This file is part of a MIOS application
* This application is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This application is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with This application; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
// Include files
#include "cmios.h"
#include "pic18f452.h"
#include "main.h"
#include "aout.h"
// Global variables
// AOUT values
unsigned int aout_value[8];
// stores the last AOUT values (to determine, if the shift registers have to be updated)
unsigned int last_aout_value[8];
// the gate pins
aout_gates_t aout_gates;
// last state of the aout gate flags to determine changes
aout_gates_t last_aout_gates;
// This function initializes the AOUT module
void AOUT_Init(void)
  unsigned char i;
  // Enable pin drivers
__asm
;; since the pins are defined in assembler-friendly syntax (-> aout.h)
;; we have to clear the pins within an ASM block
bcf AOUT_LC_TRIS_RCLK, AOUT_LC_PIN_RCLK
    bcf AOUT_LC_TRIS_DOUT, AOUT_LC_PIN_DOUT
bcf AOUT_LC_TRIS_RCLK, AOUT_LC_PIN_SCLK
__endasm;
  // clear gate pins and request update
  aout_gates.ALL = 0x00;
  last_aout_gates.ALL = 0xff;
  // set AOUT voltages to 0V and request update
  for(i=0; i<sizeof(aout_value); ++i) {
    aout_value = 0x0000;
    last_aout_value = 0xffff;
// This is an internal assembler function which updates four chained
// 74HC595 devices
// following variables are placed outside the function (instead of making them static)
// to simplify the addressing within an assembler block
unsigned char loop_ctr;    // loop counter
unsigned int aout_sr0; // chain data
unsigned int aout_sr1;
void AOUT_Load2SR(unsigned int sr0_value, unsigned int sr1_value)
  aout_sr0 = sr0_value;
  aout_sr1 = sr1_value;
__asm
        bcf    AOUT_LC_LAT_SCLK, AOUT_LC_PIN_SCLK  ; clear clock  COPIED FROM MBCV DRIVER
  ;; bcf  AOUT_LAT_CS, AOUT_PIN_CS  ; activate chip select  NOT NEEDED FOR AOUT_LC
  ;; I believe that the below might be able to be ignored for the AOUT_LC?
  ;; you will notice that the instructions are sometimes arranged
  ;; in a special order to ensure proper output signals - for example:
  ;; between a rising and a falling SCLK edge there is at least one
  ;; other instruction to ensure that the high pulse of the SCLK
  ;; is longer than 100 nS (the MAX525 datasheet specifies at least 40 nS)
  banksel _loop_ctr
  movlw  32            ; init loop counter  FOR 2 AOUT_LC modules
  movwf  _loop_ctr, 1
  ;; This is the same as the original AOUT driver with the names changed, and the latching copied from the MBCV
AOUT_Load2SR_Loop:
  banksel _aout_sr0
  bcf  AOUT_LC_LAT_DOUT, AOUT_LC_PIN_DOUT  ; set DOUT depending on current MSB
  btfsc  _aout_sr1+1, 7, 1
  bsf  AOUT_LC_LAT_DOUT, AOUT_LC_PIN_DOUT
  rlcf  _aout_sr0+0, F, 1      ; start to shift the 16-bit value
  rlcf  _aout_sr0+1, F, 1      ; second step for the 16-bit shift
  rlcf  _aout_sr1+0, F, 1      ; third step for the 16-bit shift
  rlcf  _aout_sr1+1, F, 1      ; last step for the 16-bit shift
  bsf  AOUT_LC_LAT_SCLK, AOUT_LC_PIN_SCLK  ; rising clock edge  MOVED FOR AOUT_LC DRIVER
  nop  ;; not sure it's the right place, but that works
  bcf  AOUT_LC_LAT_SCLK, AOUT_LC_PIN_SCLK  ; falling clock edge
  banksel _loop_ctr
  decfsz  _loop_ctr, F, 1      ; loop 32 times
  bra  AOUT_Load2SR_Loop
    bsf    AOUT_LC_LAT_RCLK, AOUT_LC_PIN_RCLK  ; latch SID values
  bcf  AOUT_LC_LAT_DOUT, AOUT_LC_PIN_DOUT  ; clear out pin (standby)
    bcf    AOUT_LC_LAT_RCLK, AOUT_LC_PIN_RCLK  ; release latch
__endasm;
// This function should be called from USER_Tick() to update the requested
// AOUT pins
void AOUT_Update(void)
  if( (aout_value[0] != last_aout_value[0]) || (aout_value[2] != last_aout_value[2]) ) {
    AOUT_Load2SR(aout_value[0] | (0x3000) | (0xff00), aout_value[2] | (0x3000) | (0xff00));
    last_aout_value[0] = aout_value[0];
    last_aout_value[2] = aout_value[2];
if( (aout_value[1] != last_aout_value[1]) || (aout_value[3] != last_aout_value[3]) ) {
    AOUT_Load2SR(aout_value[1] << 8 | (0x3000) | (0xff), aout_value[3] <<8 | (0x3000) | (0xff));
    last_aout_value[1] = aout_value[1];
    last_aout_value[3] = aout_value[3];
AOUT Update of the gate is missing, as i won't use them.
my two aout_lc modules are set in 8/8bit configuration,
my map.c file is configured to load 8 bit value in  aout_value[x]  :
example, for my first CV:
  // AOUT #1: forward CC7 of MIDI channel #1
  aout_value[0] = CONV_7BIT_TO_8BIT(midi_cc_chn0[7]);
there is probably useless code in the AOUT_Update function...but i've make it working doing a lot of hardware testing, and as i'm a beginner ,i'm not sure that i  understood all things fine...
thanks you all..
There is still room for improvements. ;-)
You can remove the channel selection (OR combination with 0x3000), otherwise you will get wrong results on Channel 2 and 4 (or 1 and 3? don't know).
In addition, since 32 bits are transfered with one run, you have to arrange the 8bit values in the following way:
  if( aout_value[0] != last_aout_value[0] ||
      aout_value[1] != last_aout_value[1] ||
      aout_value[2] != last_aout_value[2] ||
      aout_value[3] != last_aout_value[3] ) {
    AOUT_Load2SR(((aout_value[1]&0xff) << 8) | (aout_value[0]&0xff),
                ((aout_value[3]&0xff) << 8) | (aout_value[2]&0xff));
[/code]
otherwise the second Load2SR will overwrite the values of the first.
it's exactly why i've tested many bit manipulation!
i will try this tonight...your code is more clear!
