a little help with choosing the modules
Guest nacho
Hi everyboy, I want to make a MidiBox64 but no a full one....I'm thinking about using this modules..
CORE, 2xAIN, DIN, DOUT, LCD.....
It'll be ok with this??, do you recommend to add another module??.......
With This module configuration I will get a 64Pots (rotary and fathers) and 32 Buttons with 32 Leds and a LCD Display....It's that correct??....
Sorry for asking this simple question, but i'm not so good at english and i want to check if what I undestand reading the guides it's correct...
Thanks...
Hi nacho,
welcome to the uCApps Forum! (Posts: 1 :))
...is that correct??
Yes I think so.
...the LTC (LED/Thru/COM) module is useful if you have a need for a 2nd Midi-out and/or a Midi-thru port - and sometimes it is helpful to have information about the midi-in/out-activity (info LED's)...
MB64 Buttons // with one Dinx4 module you'll have:
4 buttons for MB64 navigation
4 function buttons (F1 - F4) // they (can) act like normal buttons with the MB64 firmware but they have special funktions with the MB64SEQ firmware...
24 normal buttons (free assignable)
Good Luck!
- Lemonhorse
// BTW - I have a lot of fun with my nearly finished 3rd MidiBox64  ;D
// visual notes: http://www.subfrequenz.net/techlog/mb64nr3.htm
Thanks for your feedback chaps (what a community ;D)!
...and again and again: THANK YOU TK!
With YOUR PROJECT you transform a piece of utopia in to a real "world-wide-web" fact.
- Lemonhorse
