Be most concerned with any LED backlit LCD display. That will be the biggest single current draw, I think... You'll also need to calculate the draw of each LED, as it will depend on the type of LED and the current limiting resistor you're using (and to some degree, max current the DOUT can source).
Ballpark figure: 5V at 1A is usually enough. Note that a lot of people have used the C64 PSU with step C control surface.
