dott.benway Posted August 19, 2006 Report Posted August 19, 2006 hi people!4 Years ago I try to midify a Siel mono, an analog sinth made in italy in 1980but in a wrong operation, I burn the main chip , a pretty rare and expensive "m110". :-((This is a 40 pin ic product by SGS in early 80, and it's used in many vintage sinth like Siel mono,cruise, or Jen SX1000.http://www.milton.arachsys.com/nj71/pdf/m110.pdf This chip scan the matrix of keyboard and a dco (clocked by 1 mhz I think) make the square wave output for the note.The m110 is very hard to find and much expensive, so i think about a project (pic based) to make a clone.In the net I have found this board but the core is an Atmel ATMEGA8L (!!!)http://www.milton.arachsys.com/nj71/index.php?menu=2&submenu=4&subsubmenu=1 (look "3.5 Keyboard" section!)At this time i'm building a 1 rack unit MIDIbox SID Synthesizer (soon the pics ...), and I ask me if is possible a project mios based like a replacement module of the dead m110.Any Idea?!?
jimhenry Posted August 19, 2006 Report Posted August 19, 2006 Why do you not want to use the Atmel project? My guess is that you could do this with a PIC processor but that it is going to be a LOT of work.
Squalie Posted August 19, 2006 Report Posted August 19, 2006 Hello dott.benway,You should check Neil Johnson's page.He built a M110 replacement with an Atmega8 controler.http://www.njohnson.co.uk/ in the Jen SX1000 Restoration section.The schematics are there and the firmare for the Atmega8 are also there.Regards,Pascal
dott.benway Posted August 19, 2006 Author Report Posted August 19, 2006 I think 3 way to resume the dead m110 : 1) I buy a new m110 chip. I have found it on e-bay for 40 €.I'ts very expensive, cause I take the sinth from a friend 5 years ago for 10 € !!!but this mean no midi, or build another midi interface pic based ...http://www.electronic-obsession.se/studio/mono/mono.htmlhttp://www.electronic-obsession.se/studio/mono/mono_mtc64.JPGhttp://www.electronic-obsession.se/studio/mono/mono_vco.JPG2) build the atmel board.Mmm ... long story. I need to build a specific programmer,install another sofware (...)@ this time I'm building 2 core modules + the pic burner: another project Atmel based sound like "no-sense"!3) A core module based project.This can be a great alternative:with a cv/gate out, I can control the synth via midi,but in this case the keyboard of the synth not work!but ... if I add an input (like a din module ? ), I can connect the matrix of the keyboard and ... GOAL!!! :-)Maybe i'ts like kill a fly with a cannon ball,but I think this is a good start point about a midify-discussion. ... and many peole are "luky" m110 owner! ;-)
stryd_one Posted August 20, 2006 Report Posted August 20, 2006 a) Easy, expensiveb) Easy, cheapc) Will take you many months of programming and lots of effort in prototyping and testing, and probably a sizable sum of $ on spare parts.Take option B mate. I don't think you realise just how hard option C is.
Sebo Posted August 27, 2006 Report Posted August 27, 2006 Hi:I have the same problem but with a 4 voice polyphonic Yamaha CS-50 (thechip that sacan the keyboard matrix is broken, and is very hard to find and expensive).I buyed a a PAiA MIDI to CV interface very cheap (second hand), but is V/Octand I need Hz/Oct so I'm in the process to do some mods to it.But I can't use the beatiful keyboard (that have aftertouch). So I'm planingto add a PIC based circuit to scan the matrix and convert the signals to MIDI.I found this project http://tomscarff.tripod.com/key2midi/key2midi.htm basedon a PIC16F877, is really simple.Sebo
Tanstaafl Posted August 27, 2006 Report Posted August 27, 2006 Hey Sebo, PAIA makes an add on board that will turn the V/Oct to V/Hz. 9700vhz midi2cv8 Volts/Hertz Option includes all components and circuit board with mounting hardware .............. us$14.25 (5.00)the above from thier website at:http://paia.com/midi2cv.htmgb
stryd_one Posted August 27, 2006 Report Posted August 27, 2006 I found this project http://tomscarff.tripod.com/key2midi/key2midi.htm basedon a PIC16F877, is really simple.Did you check out QBAS's MIOS-based keyboard scanning matrix?
Sebo Posted August 29, 2006 Report Posted August 29, 2006 HI ppl:Tanstaafl:Thanks for the advice, but PAiA is not selling the CV/Hz converter anymore.I contacted them and they give me the schematics and some info. I'm inthe process of making it, but the transistors that the circuit uses aren'tavlaible in my country, so I'm triying some others.stryd_one:I didn't know about it, I gonna do a search at the forum. Thank you.Sebo
dott.benway Posted August 31, 2006 Author Report Posted August 31, 2006 Hi Mr. Sebo!what's the name of the Chip broken?I buy for 40 euro a M110 @ this page : http://www.vintagechip.altervista.org/Maybe u can find your chip .(...)Do u need a black box like this? _____ >-- V/oct ---| | | VCO | ----> /\/\/\/\ (square wave) |_____|Try this simple schematic:http://www.uni-bonn.de/~uzs159/vco4069.html (...) A very very good analog keyboard interface project is this :http://www.musicfromouterspace.com/analogsynth/AAA_VControllerIndex.htmlhttp://www.musicfromouterspace.com/analogsynth/matrix_keyboard_may2004/matrix_keyboard_may2004.htmlMaybe this can be a great T.O.S. substitute(T.O.S. mean Top Octave Synthesizer or what?!? )Soon the pictures of The "re-animation" of my Siel mono !!! ;-)
Sebo Posted September 1, 2006 Report Posted September 1, 2006 Hi dott.benway:Thanks for the links & info.Sadly that site don't have the chips. They are customs chips made by YamahaYM2600 & YM2700.The big problem is that most people want them for the bigger CS-80 so whensomeone have one ask a really high price, that sometime is most that my CS-50costs :(I will check the sites for the keyboard interfaces.Sebo
