I'm building a new application. I've searched the forum and Wiki, I can't seem
to find an answer to this..
My project needs just one encoder + one button. When I study the skeleton
project, It seems to require me to identify which DIN register the encoder is
connected to.
Can I use the MIOS encoder handling without using a DIN board? There's plenty
of available pins on the core that should work.
Thanks,
LyleHaze
no, it's not possible to use encoders without DIN. But you don't need to build a PCB, just mount it on the same vectorboard to which the rotary encoder/button is mounted - the 74HC165 is just a small chip and costs about 0.35 EUR - no need to provide alternative solutions
