Alkex Posted September 7, 2006 Report Posted September 7, 2006 Hi there,I have a rather confusing problem.No matter what Pins I attribute to various menu buttons in cs_menu_io_tables.inc, Din pins 0 & 1 of the first shift register always call up the ADSR edit screen, and act as up/down cursors to the REL Value.I am using an encoder, 4 selection buttons and an exe button, all located around shift registers 3 and 4, the first two used for a piano keyboard.I have disabled the up/down cursors in main.asm and set all other menu shortcut pin adresses to sr 0 pin 0Any suggestions as how to disable pins 0 & 1 ?Thanks in advanceAlex Quote
TK. Posted September 7, 2006 Report Posted September 7, 2006 Hi Alex,check the encoder entries in mios_tables.inc, maybe you've still assigned an encoder to pin 0 and 1 - this overrules the button handler.Best Regards, Thorsten. Quote
Alkex Posted September 11, 2006 Author Report Posted September 11, 2006 Thanks Thorsten,Indeed you where right,I had only set the SR to 0, apparently Pins must be set to 0 also..Thanks for making my day, AGAIN!!Best regardsAlex Quote
Mr modnaR Posted September 12, 2006 Report Posted September 12, 2006 i love your midibox! what did you cannibalize to get that case? was it a korg controller for their ms20 etc emulation software? Quote
Alkex Posted September 12, 2006 Author Report Posted September 12, 2006 Hi Mr ModnaR,Nope, it was an old 70s Bontempi toy I picked up for 1.50€ from a charity shop and resprayed ;DI then had 2 Shaeffer panels made to sizeI would really recommend Bontempi toys for keyboad projects as they are really simple to resolder and contacts are immortal!!Glad you like my Sid CheersAlkex Quote
Mr modnaR Posted September 12, 2006 Report Posted September 12, 2006 i'd never have guessed! congratulations, it's come out really nice. Quote
Therezin Posted September 12, 2006 Report Posted September 12, 2006 A bontempi organ? into one of the coolest SIDs I've seen in a long time? That's beyond crazy. I want one. ;D Quote
