fstop Posted September 10, 2006 Posted September 10, 2006 okay so i have an american dj - 2x cd dj deck with removeable control surface - i was wandering if there would be any way to *hah* easily turn this into a midi controller - the idea would be to use it as an interface for something like traktor dj - as i think it would be perfect. anyone?
MRE Posted September 11, 2006 Posted September 11, 2006 essentially two options... neither of them exactly 'simple'1: hack out everything and figure out a way to get to the button wires and hand wire everything part by part to the midibox core.2: Hook the thing up to a deck through some sort of Logic Analyser and figure out the control protocol, then write an interface application for Midibox.The second would be more universally usable by other people, and would be the more worthy project. Yeah.. enjoy that one. ;)
audiocommander Posted September 11, 2006 Posted September 11, 2006 an american dj - 2x cd dj deck with removeable control surfaceI'd stick to MTEs first suggestion.- Buttons are no problem at all, go into DIN-modules /up to 64 per module- Potentiometers should have linear 10k resistance, you could check these with a multimeter. If they got these values, you can directly connect up to 32 of them (AFAIR) to one AIN-module AINx4-module- LEDs go directly to AOUT-modules DOUT-modules- LCDs: check for type (Graphical/Character; there are some custom drivers available for graphical LCDs); in the worst case this can be exchanged completely- additional parts have to be checked for compatibility. there are some tricks however to connect non-fitting parts. If you find some strange parts, you could send some details!The question would be if you're interested in keeping the cd deck working and adding midi-functionality? Dunno what to do there; depends on the voltage-levels and functions inside (be careful if there are high voltages in there! can be lethal!!)Best regards,Michael
stryd_one Posted September 11, 2006 Posted September 11, 2006 That's:If they got these values, you can directly connect up to 32 of them (AFAIR) to one AINx4-moduleLEDs go directly to DOUT-modulesAC must be overworked :) ....Or breathing solder fumes hehehe... But he is right IMO, go with option 1.
audiocommander Posted September 11, 2006 Posted September 11, 2006 uhh, yeah... overworked... this would be an expensive box, connecting 128 LEDs to 32 AOUT modules ;D ...sorry for the misinformation, fstop ;D and thanks stryd for correcting this!
MTE Posted September 11, 2006 Posted September 11, 2006 What was my suggestion ?? ...dont remember ::) ;D1 Hint : For an Traktorcontroller theres no need for an LCD cause Traktor sends no mididata out.You configure the box 1 time for the traktor-software, only for pre-programming a lcd is good for debuggin..@ AC Buttons are no problem at all, go into DIN-modules /up to 64 32 per module ;)RegardsMTE
Wild_Weasel Posted September 11, 2006 Posted September 11, 2006 Hi!I did what MRE mentioned under #1, look here for details http://stud3.tuwien.ac.at/~e0327352/and search the forum for further details.The only hard part was to write a C program which makes use of the jog wheel und shuttle ring.The rest was just straight midibox/ MIOS stuff.Aaaaaaaand I am planing on doing it again (now that I am learned the hard way). Look here:http://stud3.tuwien.ac.at/~e0327352/midibox/denon%20mb%202/I am sticking to denon control units again since I think that they are very well built.ad MTE:Ich glaube es wird wirklich Zeit für eine MIDIBOX Traktor um das ganze Wissen um Traktor Controller im zB Wiki zu sammeln. Anscheinend ist doch einiges an Interesse vorhanden.Grüsse m.
MTE Posted September 11, 2006 Posted September 11, 2006 @ Weasel 1st step done ;)http://www.midibox.org/dokuwiki/doku.php?id=midibox_traktor
Wild_Weasel Posted September 11, 2006 Posted September 11, 2006 ad MTE:SELEKTOR added in Wiki. More to come ...Regardsm.
MRE Posted September 12, 2006 Posted September 12, 2006 is it confusing that there is both an MRE and MTE user on the forum?! hehe
