Alo. :)
I've been running an idea over in my head of a light bulb rig where each bulb can be turned on or off via a midi message. As far as I can tell, I would need a core module (naturally) and a dout module with a ULN2803.
I have a few technical questions though.
1. Do I interface the ULN2803 to the 74HC595N in the dout module or can I just put the ULN2803 into the socket without needing a 74HC595N?
2. Do the +/- points of the bulb or the bulb socket just connect to the dout output pins/ground pin?
3. Is there a way to have the bulbs turn off after a period of time? i.e 500ms or 1s. Would this be software or hardware based?
I'm sorry if the answers to these questions are obvious, just thought i'd get a definitive answer.
Thanks very much :)
The ULN2803 is just a driver for the load (in your case lamps). You'll have to connect them after the 595. Just as mentioned here: http://www.ucapps.de/midio128/relay_example.pdf
No... see the link above. Just substitute "relay" with your lamps. But also take care on the max. load of the ULN outputs. See here: http://www.ucapps.de/midio128/uln2803.pdf
greets
DOC
Both would be possible. It's easier with software. Doing it by hardware means you'll have to connect a timer (555 for example) between every 595 and the ULN.
