LO Posted April 2, 2003 Posted April 2, 2003 Helloseveral questions this time!If I want to use the midibox link do I need to:*Run any special firmware?*Must it run on at least 2 18F's? or can I mix and match cores?cheersLO
LO Posted April 2, 2003 Author Posted April 2, 2003 Helloseveral questions this time!If I want to use the midibox link do I need to:*Run any special firmware?*Must it run on at least 2 18F's? or can I mix and match cores?cheersLO
TK. Posted April 3, 2003 Posted April 3, 2003 Hi Lo,MIDIbox Link is natively supported by MIOS and is also compatible with the PIC16F implementation :)To enable this function, add following line to the initialization routine: movlw MIOS_MIDI_MERGER_MBLINK_EP call MIOS_MIDI_MergerSet for a MBLink endpoint movlw MIOS_MIDI_MERGER_MBLINK_FP call MIOS_MIDI_MergerSet for a MBLink forwarding pointBest Regards, Thorsten.
