lemonhorse Posted October 22, 2006 Posted October 22, 2006 Hi,ich habe gerade bei einem SID Step B v1.7303b eingespielt - alles scheint zu funktionieren :)Jedoch im Menue: {OSC (oscillators), FIL (filters), LFO (low frequency oscillators), ENV (envelopes), MOD (modulation matrix),WT (wavetables), WMA, 303, SEO, CFG (configuration), SAV (save patch)} fehlt der Eintrag "SAV" - ich kann somit nicht speichern.Habe ich etwas übersehen? - kennt jemand das Problem? - oder habe ich den Menuepunkt verloren weil ein 2x16 LCD nicht mehr "erlaubt" ist?Gruß,Lemonhorse
TK. Posted October 22, 2006 Posted October 22, 2006 Hallo Lemonhorse,ein 2x16 LCD ist nach wie vor erlaubt, Du musst jedoch in main.asm (bzw. im setup_* File, welches Du verwendest), den Eintrag:#define CS_MENU_DISPLAYED_ITEMS 5auf 4 setzenGruss, Thorsten.
lemonhorse Posted October 23, 2006 Author Posted October 23, 2006 Hallo Thorsten! :) ;; Prepared Setup File for 6581 SID; After this file has been assembled, execute "convert.bat" from a DOS shell; to generate 4 .syx files for all master/slaves;#define SEPERATE_SETUP_FILE 1 ;; here you can change the default device ID - if you are using ;; some cores as slave, set: ;; o DEFAULT_DEVICE_ID 0x01 ; for the first slave ;; o DEFAULT_DEVICE_ID 0x02 ; for the second slave ;; o DEFAULT_DEVICE_ID 0x03 ; for the third slave#define DEFAULT_DEVICE_ID 0x00 ;; if this option is enabled (1), the DEFAULT_DEVICE_ID won't be used, but ;; it will be automatically derived from the MIOS Device ID instead#define AUTO_DEVICE_ID 1 ;; this MIDI channel will only be taken when: ;; - you are using the MBSID standalone (neither as CS Master, nor as CS Slave) ;; - the control surface is diabled and a BankStick is connected ;; in all other cases, the MIDI channel of the Master or Slave has to be selected ;; from the Control Surface#define DEFAULT_MIDI_CHANNEL 1 ;; select the BankStick type you are using here: ;; 0: "normal" 24LC256 EEPROM (32k), up to 8 EEPROMs can be connected for 8 banks ;; 1: 24LC512 EEPROM (64k), up to 4 EEPROMs can be connected for 8 banks ;; (it is not possible to mix 32k with 64k EEPROMs, more than 4 64k devices not supported)#define DEFAULT_BS_TYPE 0 ;; select the filter type here: ;; 0: if a 6581 is controlled from the core ;; 1: if a 8580 is controlled from the core ;; 2: 6581 + freely definable scaling (define MIN and MAX value below) ;; 3: 8580 + freely definable scaling (define MIN and MAX value below)#define DEFAULT_FILTER_TYPE 0 ;; only relevant if DEFAULT_FILTER_TYPE is 2 or 3, values between 0 and 2047 are allowed#define DEFAULT_FILTER_CALI_MIN 20#define DEFAULT_FILTER_CALI_MAX 1000 ;; set this if you want to switch between two different types and Min/Max values#define DEFAULT_FILTER_TYPE_SWITCH 0 ;; and define the used pin here (default: pin RC.3)#define DEFAULT_FILTER_TYPE_SWITCH_TRIS TRISC#define DEFAULT_FILTER_TYPE_SWITCH_PORT PORTC#define DEFAULT_FILTER_TYPE_SWITCH_PIN 3 ;; define the type (0-3) and the Min/Max values (for type 2/3) here:#define DEFAULT_FILTER_TYPE2 1#define DEFAULT_FILTER_CALI_MIN2 0#define DEFAULT_FILTER_CALI_MAX2 2047 ;; set this to '0' to disable the control surface - this is especially usefull for ;; people who want to program their own CS handler in order to free ;; some memory ;; It's also a good idea to disable the CS if the core is running as SID slave ;; (although this is no requirement!)#define CS_ENABLED 1 ;; if this option is set to "1", the CS will be enabled if the MIOS device ID is 0x00, and ;; it will be disabled if the MIOS device ID is != 0x00 ;; in other words: the control surface will only be enabled for the master ;; note that this mechanism doesn't remove the CS code like CS_ENABLED == 0#define AUTO_CS_ENABLED 1 ;; number of visible menu items on LCD ;; use: 4 for 2x16 displays ;; 5 for 2x20 displays ;; 10 for 2x40 displays#define CS_MENU_DISPLAYED_ITEMS 4 ;; NOTE: if CS_MENU_DISPLAYED_ITEMS > 5, you have to adapt the DIN settings ;; in cs_menu_io_tables.inc ;; OLD_STYLE == 1: page scrolls with the cursor ;; OLD_STYLE == 0: page scrolls directly with the datawheel#define CS_MENU_OLD_STYLE 0 ;; Inc/Dec buttons or rotary encoder of data entry? ;; use: 0 if rotary encoder should be used ;; (pins of encoder are defined in mios_tables.inc) ;; 1 if buttons should be used instead#define CS_MENU_USE_INCDEC_BUTTONS 0 ;; use: 0 if a non-detented encoder is used to select the menu items ;; 1 if a detented encoder is used to select the menu items ;; the CS_MENU_EncSpeedSet function in "cs_menu.inc" sets the speed ;; depending on this value#define CS_MENU_USE_DETENTED_ENCODER 1 ;; the speed value for the additional encoders (#2-#15) is defined here ;; Hint: for non-detented encoders try the following: in mios_tables.inc ;; set the type of all encoders to "MIOS_ENC_MODE_DETENTED2" in order to ;; reduce the resolution (e.g. 24 ticks per revolution for a ALPS STEC16B), ;; set the speed value to 3 --- result: so long as the encoder is moved ;; slow, the parameter can be changed very precisely. By moving the encoder ;; faster, it is possible to sweep over the whole value range with a single turn ;; ("Progressive Mode")#define CS_MENU_ENC_SPEED_VALUE 3 ;; set this define to 1 of the link to slave SIDs should be enabled by default#define CS_MENU_DEFAULT_LINK 0 ;; if 0: OSC button selects also combined modes (7 states, combined OSCs) ;; if 1: OSC button selects only one of three OSCs (faster handling)#define CS_MENU_OSC_BUTTON_BEHAVIOUR 1 ;; use PORTA and PORTE (J5 of the core module) as output ;; you can address these pins in cs_menu_io_tables.inc as "shift register" #0#define ENABLE_J5 0 ;; set this to '1' if the modulation matrix (8x7 LEDs) is connected to the DOUT chain#define MOD_MATRIX_ENABLE 0 ;; define the shift registers (note: HERE the shift register begin with 0: 1st SR is 0, 2nd is 1, 3rd is 2, ...)#define MOD_MATRIX_ANODES 6 ; shift register with anodes (HERE: 7th shift register in the chain)#define MOD_MATRIX_CATHODES 7 ; shift register with cathodes (HERE: 8th shift register in the chain); For MIDI activity monitor: define the DOUT pins for the Rx and Tx LED:#define MIDI_RXTX_USE_J5 0 ; if 0: MIDI Rx/Tx LEDs are assigned to the DOUT chain, pin 0x00-0x7f ; if 1: MIDI Rx/Tx LEDs are assigned to J5 DOUT, pin 0x00-0x07 ; (in this case ENABLE_J5 has to be set to 1!)#define DEFAULT_MIDI_MONITOR_ENABLED 1 ; if 1, the Tx/Rx LEDs are enabled#define DEFAULT_MIDI_RX_LED 0x41 ; DOUT SR#9, pin D1#define DEFAULT_MIDI_TX_LED 0x42 ; DOUT SR#9, pin D2 ;; enable access to the AOUT module via Port J6 ;; (status: experimental)#define ENABLE_AOUT 0 ;; enable the 6th LFO waveform (analog inputs)#define ENABLE_AIN_LFO_WAVEFORM 1 ;; sets the default display mode for the LED matrix ;; 0: shows modulation assignments after power-on ;; 1: shows modulation meters after power-on ;; the mode can be toggled by pressing two mod target buttons at the same time (e.g. O1 and O2 Pitch)#define DEFAULT_LEDMATRIX_MODE 0#include "main.asm"Der Eintrag war bereits auf 4... ???
TK. Posted October 24, 2006 Posted October 24, 2006 Hallo Lemonhorse,irgendetwas ist mit Deiner Datenhaltung nicht in Ordnung - in der offiziellen Release steht der Eintrag auf 5. Ich habe gerade den Wert 4 ausprobiert - funktioniert.Ich kann mich erinnern, dass es in irgendeiner Beta Version schonmal Probleme mit diesem Setting gab, doch die sind schon laengst gefixed...Gruss, Thorsten.
lemonhorse Posted October 25, 2006 Author Posted October 25, 2006 Sorry TK,vermutlich liegst Du richtig :-\Anbei ein visueller Gruß von (m)einer MidiBox an seinen "Vater" ;)
lemonhorse Posted October 25, 2006 Author Posted October 25, 2006 Der Feher lag in dem MPLAB Projekt (falsche bzw. veraltete Path-Einstellung!).Jetzt kann ich wieder SAVen 8)+ Gleich mal die neuen Optionen testen :)Danke für den Tip TK.Gruß,Lemonhorse
TK. Posted October 25, 2006 Posted October 25, 2006 Dein Gehaeusedesign ist wirklich sehr individuell! :)Gruss, Thorsten.
