jackchaos Posted October 27, 2006 Posted October 27, 2006 Is it possible to cast from Char to Int?Like: unsigned char a = 5; unsigned int b = 1000; int c = b * (int)a; When I try to do such a thing I get the following error when running make: Compiling main.c Processor: 18F452 ================================================ Linking project error: missing definition for symbol "__mulint" ERROR!
jackchaos Posted October 27, 2006 Author Posted October 27, 2006 Never mind, I found this document.http://www.midibox.org/dokuwiki/doku.php?id=stryd_one_codeblocksWhich introduces me to Code:Blocks and I believe the included LIB is what's helping me.You guys are great.
DavidBanner Posted October 27, 2006 Posted October 27, 2006 why would you want to store an int in a var char?
audiocommander Posted October 27, 2006 Posted October 27, 2006 http://www.midibox.org/dokuwiki/doku.php?id=c_tips_and_tricks_for_pic_programmingsee Arithmetic Calculations ;)
jackchaos Posted October 27, 2006 Author Posted October 27, 2006 why would you want to store an int in a var char?I have a lookup table filled with unsigned chars that define the config and behavior of each and every pot. One of the items is a refresh interval that later gets multiplied by 500 (this may change later).This is the only way I can see how to do it... and yes, I'm doing a multiplication the bad way (a = b*c).http://www.midibox.org/dokuwiki/doku.php?id=c_tips_and_tricks_for_pic_programmingsee Arithmetic CalculationsI'm at work right now, but from what I see in this document. If I change my 500 (above) to 512and do a bit shift like so:a = 2 << 9; // a is 1024ora = 5 << 9; // a is 2560This would be the equivalent of:a = 2 * 512;or a = 5 * 512;If this is true, I've solved that problem and I can make the changes when I get home.Thanks again!( audiocommander, yes. I meant 'a = 2 * 512;', It's corrected above. Thanks. )
audiocommander Posted October 27, 2006 Posted October 27, 2006 I'm sure you mean a = 2 * 512, then it's correct and you'll save a lot of codespace and calculating power this way ;)Cheers!Michael
DavidBanner Posted October 27, 2006 Posted October 27, 2006 out of sheer morbid curiosity - why store the var in a char and not an int?
jackchaos Posted October 27, 2006 Author Posted October 27, 2006 unsigned char two_dimensional_array[NUM_POTS][NUM_OPTIONS]The array can only hold one value type. I'm storing all my config here and every value is a char.I want the option to scale all the update intervals so the interval is later multiplied by another number which is higher than 255.
