jackchaos Posted November 25, 2006 Report Share Posted November 25, 2006 I'm finishing off the last bit of electronics for my panel and I've decided to use 1 encoder as a menu data wheel.My encoder is from SMASHTV's site and I'm confused on the wiring for the 3 pins.Below is an image of the encoder:Encoder wiring diagrams suggest 2 of the pins connect to a DIN module and 1 of them to VS.Does it matter which one goes to VS? Quote Link to comment Share on other sites More sharing options...
doc Posted November 25, 2006 Report Share Posted November 25, 2006 Hi,Encoder wiring diagrams suggest 2 of the pins connect to a DIN module and 1 of them to VS.Does it matter which one goes to VS?sure this matters!Encoder pins are normally named: A, B, C (common)If I have Smash encoders right in mind the middle pin should be C (wired to Vss). A and B are the switches.ALPS Encoder have a different connecting.Someone can verify this please? Quote Link to comment Share on other sites More sharing options...
jackchaos Posted November 25, 2006 Author Report Share Posted November 25, 2006 GotchaC is the middle one:Thanks doc Quote Link to comment Share on other sites More sharing options...
