ultra Posted November 30, 2006 Posted November 30, 2006 after searching the forum, wiki, and midibox site, i'm still left with some basic questions. i'm sure this information is available, and i've done some searching, but i've yet to figure these things out.how do i go about connecting the din and dout modules to the core? i'm sure some sort of ribbon cable will be used to connect to the pin headers, but what specifically should i purchase? i'd like to have them pre-made. which way do i hook them up?what's the best and easiest way to connect the lcds to j15?is there some sort of wiring guide showing me how to connect encoders, buttons, leds, etc?is there an aout kit available anywhere? i've bought the kits from smashtv but there's no aout available on his site. i'm assuming this is what i'd need to add cv to the sequencer.any general or organizational tips on testing this out before i figure out what to do about making a case?thanx!
oshidash Posted November 30, 2006 Posted November 30, 2006 Hi !i'm sure some sort of ribbon cable will be used to connect to the pin headersBingo!Well, people got different preferences.. of course you can buy ribbons with attached sil-headers..you could check www.reichelt.de oder www.mouser.com for thatAOUT-LC_V.1 to be found here for example:http://www.mikes-elektronikseite.de/shop_englisch/index.htmso longoshidash
ultra Posted November 30, 2006 Author Posted November 30, 2006 thank you for the response. how about wiring? this is the configuration i've figured out based on the reading i've done, but i'm not sure if it's right.din modules to core (are these configurations correct?):core (j9) to din1 (j1)din1 (j2) to din2 (j1)din2 (j2) to din3 (j1)the headers on the din modules are 10 pin and j9 on the core is 5. do i only use one row of headers on the din module? if so, which row? how do i know which way to connect the plugs?dout module to core (and these?):core (j8) to dout (j1)same as previous question. only one row of headers?if these are correct, in the end will i need 4 sets of 5-pin cables and 1 16 pin cable for lcd?on smashtv's site, on the dout module, j3-6 are listed as "digital input lines". are these the connections to the various leds? i would figure they'd be labeled as output lines, not input. how do i know what to hook up to what on those pins?on the din module, j3-6 are labeled the same. are these connections coming from the encoders and buttons? again, how do i know what to hook up to what?i read a post somewhere (from last february) that said a tutorial was being developed for the wiki, but i can't find it there. has this made the light of day? if so, that would be excellent.thanx!
dcer10 Posted December 1, 2006 Posted December 1, 2006 Hiya ultra,Welcome to the start of the process that will bring you the best sequencer in the world!! Firstly, dont take my advice as the best answer, there are a lot of people on this forum, and some are VERY good at building these devices!! Theres always a better answer!!Dont be too stressed about all of the interconnections as its not as hard as it sounds. The basic rule is to download all of the PDF files from the main site and follow them no matter what. The newer model smash boards look different but follow the same pinning as the PDF files. Any changes are listed on smashes site. His site is also a good thing to have in front of you while building his boards.With the LCD cable I have made a few and have found that if you put a female DIL connector on the core and on the back of the screen and make a ribbon cable 1:1 between them (dont worry that your connection may not be 1:1) then you cut the ribbon in the middle and label each lead (follow the lead to its source to find the label) and re join them so they all match up again. I suggest when soldering ribbon cable to ribbon cable to tin the ends and make small hooks that then join each other an to put heat shrink seal over the join. This has proved to be the best connection for me so far. This technique is only really for the 40x2 lcds as I have found the pinning never matches the core. If your pinning of the screen matches the core then disregard this.With ribbon cables you dont need to order them. Just buy some wide ribbon and the right dil connectors and do it in a vice, its much cheaper that way. Another good tip is to build it all out on a table before putting it into any case. This will make sure it works and give you a good idea of the case size etc needed.Also, its not the best way to do it, but you can solder the ribbon directly to the pins if you dont want to buy/make the connections. This is actually handy for some connections anyway when a DIL has to go to 2 seperate SIL rows ie core J8 and J9 go to Dout and Din from one DIL set. Of course there are other better ways to do this too.Another tip is on the smash boards, there may be a DIL there but only connection names on one side. Unelss you have checked that the connection is joined on the PCB with your multimeter only use the labeled pins. An example of this is on the Din boards. I have a DIL connection and was trying to use the 2 end pins as VS thinking they were joined, they arent!din modules to core (are these configurations correct?):core (j9) to din1 (j1)din1 (j2) to din2 (j1)din2 (j2) to din3 (j1)Yes that is correct. dout module to core (and these?):core (j8) to dout (j1)Another thing is that if you are soldering to the pins, join the VS earth one first as its always on one end (use multimeter to make sure its the right one back to its source) then work away from the VS cable by cable as they seem to be mostly in the same order. This way you dont need to check which is which as often (only when there is a problem). Maybe I shouldnt share too many lazy type habbits like this tho :) This one is mostly for when connecting boards from mikes shop as there is no label.the headers on the din modules are 10 pin and j9 on the core is 5. do i only use one row of headers on the din module? if so, which row? how do i know which way to connect the plugs?J9 core goes to J1 din. Connect each labeled pin to the matching one on the din or dout. 1 row is for the din one for the dout. The DIL header on the core is labeled J8 J9 in the right order. On the din board the 10 pin connections are to go to the buttons and encoders. 8 per set are actually used, one is earth (vs) and one connects to nothing. When using these 10 pin connections you can make yourself a diagram so you can count the ribbon cables (I have the red cable on one end matching the DIL header) and write (after testing with a multimeter) what they connect to for easy reference ie ribbon 1 -> D0 2 -> D1 etc (that might not be the actual connection, check yourself).if these are correct, in the end will i need 4 sets of 5-pin cables and 1 16 pin cable for lcd? I think you will need a lot more cables than this to complete the sequencer. Have a look at the pdf files to check, you need connections to the core for each board, also you need connections from each din/dout to buttons, encoders, leds etc. on the din module, j3-6 are labeled the same. are these connections coming from the encoders and buttons? again, how do i know what to hook up to what?These all are called shift registers (SR) and each IC chip is one SR. Each SR has 10 pins on the smash version and 8 of those 10 go to buttons or encoders. Buttons take 1 pin, encoders take 2 pins. You can download the PDFs that show the din/dout connections for each application. Here are the ones for the seq:http://www.ucapps.de/midibox_seq/mbseq_din_v2.pdfhttp://www.ucapps.de/midibox_seq/mbseq_dout_v2.pdfAlso with the Aout, if you want to have 8 channels of the CV/Gate buy the Aout not the Aout LC board. You will have to find all the parts yourself, but the only ones that are harder to get are the Maxic 525 chips and the little shunt that goes on the bottom. You can order samples from maxic for these chips if you cant find a dealer who can sell them to you.If you want a V3 seq you should put in at least 1 IIC board now, and I would also consider an 8 chip bankstick board, and an LTC module to get the most out of it.With the wiki I dont think there is a manual showing a step by step instruction. I have had almost every imaginable problem finishing mine, so I will try my best to chip in and help you out when I can.A quick troubleshooting guide when hooking up something and it doesnt work:0) Always plan what you are going to do first, measure things, think about them before doing them and make sure you have all the tools and infomration to do it first. This is especially true for the case, and also for the electronics.1) Always read the PDF first, look at it, think about it, look at it again, then pick up the soldering iron.2) Always check the test voltages before putting IC's in. This is clearly stated on the main ucapps site for each module what the voltages would be.3) Test for connections being set up correct, use multimeter to beep out end to end. Refer to PDF to figure out what goes to what.4) Check if all IC's are orientated the right way5) Swap IC's on the DIN/Dout if all else fails (these IC's seem to fail a lot I have found??)I hope this has been of some help for you.All the best,John
ultra Posted December 1, 2006 Author Posted December 1, 2006 thank you for the reply. i was unaware of any pdfs even though i did search around. i probably missed something right in front of my face :). i'll grab them and use your tips and hopefully over the weekend i'll have something started. thanks again!drew
stryd_one Posted December 1, 2006 Posted December 1, 2006 I'm not sure where it would fit, but that post would look good on the wiki ;) Good info...
Dolphinicus Posted December 1, 2006 Posted December 1, 2006 That's excellent info. that I'd been searching all around the place, FOR! :D Thank you greatly dcer!! :) :)In reference to connecting the Core to my first completed DIn module, it took me a few hours over 3 days to realize why it's not working - was due to my hooking up the 'SO' to the 'SO'. Figured that out yesterday, and my first perfboard of 8 buttons now works fine, in testing it with the MIDIO128 app. :) (Seeing Ultra's mention of that, in his message).I'll just have to pick up some 5 pin SIL connectors for ribbon cable, this weekend. :)Off on a minorly related tangent ...... still trying to figure out the best way to enclose my LEDs above my tact switches. (Which have 9mm stems.) I'd originally thought of and tested clear silicone, which works wonderfully - but the thought earlier this week that occurred to me were: could repetitive touching of silicone, leave any type of residue on my finger(s) that would be poisonous? I'll have to go and search for the MSDS sheets for silicone to find out, before making ...... 37 LEDs (for switches) like that. :o (To see if it's safe. I hope it is, because they sure look great! :D )Off on one last minorly related tangent ....... I tried a test today, for labelling my panels (which are wood). I applied a few colours of pencil crayon to the panel which I may be using for my MIDIbox SEQ. (Which I colour my knobs with - see my webpage in my sig for a photo example).I then applied a portion of water based purple stain to the wood, to see if the pencil crayon colourings would REPEL the stain - so that they show through. It looks like the pencil crayon markings DO! :D I'm going to test it on the wood again, once I sand it, before colouring with pencil crayons - to stain it again. If it works as well as I hope - all of my panel labelling for my entire modular synthesizer will be done with pencil crayons. :) (Including relevant art / etc. for each panel mounted device.)K. Sorry about ranting ..... :o :) Just remembered: I went to www.maximic.com to see about ordering 2 MAX525's as samples, but I couldn't. :( They exceeded the sample amount limit. :( :( (Bummer - as I've ordered samples from them before.) I'll be checking back with them later to see if I can purchase them directly from Maxim. Oh well. :)
ultra Posted December 16, 2006 Author Posted December 16, 2006 i think i found an organized solution to connecting everything. for anything that is not a 1:1 connection, i'll run a straight 1:1 cable from the core or each module to a grid style pc board, make the connections that need to be changed on the board, and the run them out from another 1:1 cable to wherever they need to go. it's probably more expensive for the extra parts but having all the non 1:1 connections right there in front of me will probably save me on buying headache medication. has anybody tried this?smashtv's site doesn't give part numbers. does anybody have the numbers for the plugs and encoders?
