DavidBanner Posted December 12, 2006 Posted December 12, 2006 Hi All,Have some questions regarding the midiFeedback in Abletondoes anyone know either of the following:a) how to go about writing custom MIDI remote scripts?b) in particular how would I go about mapping the buttons (i.e. the "power button" or one of the Eq kill buttons) on a plugin (i.e. the Eq 3 plugin) to a midi event, so when you press the button using the mouse it sends a midi event?
cimo Posted December 12, 2006 Posted December 12, 2006 a) no idea, i don t think it s possible but i also think that everything is possibleb)it is already there, when you actuate on a plugin with the mouse it will send a midi output (a small coloured square in the upper right corner will notify you), just remember to activate a proper midi device in the preferencessimone
audiocommander Posted December 12, 2006 Posted December 12, 2006 Hi David,I think, you're searching for this one here:I've done some more test with this hack, and it seems to work with all controls that can be assigned to a MIDI note number. I'm yet to try CC's.http://www.midibox.org/forum/index.php?topic=6532.15;)Cheers,Michael
DavidBanner Posted December 12, 2006 Author Posted December 12, 2006 ahhh ha! I think I see the issue I was having....Stuff like the clips, solo etc were sending midi but the Plugs weren't - I thnik I have to enable and assign their midi 1st....excellent - thanks fellas
mr_chombee Posted December 12, 2006 Posted December 12, 2006 hello,to answer your first question, it is possible to create custom scripts in Live 6. please find the following folder and read through the text files:OSX:/user/library/preferences/Ableton/user remote scriptsWinXP/2000:c:/documents and settings/[username]/application data/ableton/live x.x/preferences/user remote scriptsNote that on some Windows systems the application data folder is hidden by default. Here is what you have to do to make it visible: 1. Launch Windows Explorer. 2. Select Tools/Folder Options/View. 3. Check "Show hidden files and folders."You could also check this thread:http://www.ableton.com/forum/viewtopic.php?t=47157best regards,nico
cimo Posted December 13, 2006 Posted December 13, 2006 Remember to check if the plugin can send midi output, not all of them can do it.Ableton does it for sure, exept for a few parameters, but if the plugin sends midi.ableton will transfer it to the midi output if any.simone
Sasha Posted December 13, 2006 Posted December 13, 2006 I would go with LC. In Ableton Live 6 there is a list of Control Surfaces in Preferences where you just need to select Mackie Controll and IN/OUT. I tested it a and it works OK, but again, it can be used only for controling parameters suported by Ableton Live MIDI. In Live 6 midinotefeedback don`t work and Live reports error. In Live 6 kill buttons of EQ3 are MIDI mappableDavid, what power button are you talking about? Do you mean Device Activator button on the corner of plugin? If so, it can be mappable too.
DavidBanner Posted December 13, 2006 Author Posted December 13, 2006 hi all,I'm on top of it all now - all I needed to do was to activate the midi of the object (i.e. button etc) and it starts sending the midi data.The LC script won't do - I have lots more stuff that I need to do that the LC doesn't support (have already been playing with it).Do you mean Device Activator button on the corner of plugin? If so, it can be mappable too.yeah - I know, have mapped it b4, but didn't have ableton in front of me and wasn't sure how to activate the midinote feed back - again all sorted now.In Live 6 midinotefeedback don`t work and Live reports error. mmmm, this is worrying!I guess everything will have to be done with a script...
