Dauwige Posted January 14, 2007 Posted January 14, 2007 What is the best or maximum for the banksticks?Can i connect different chips on the bankstick pcb?I know that the maximum would 8 x 512 = 512K, but for song data is only the max. 32k.So is the following the maximum?6x 24LC512 for pattern and 2x 24LC256 for song and mixer?Is´s posible to connect two or more bankstix pcb to the core?So how many 24LCXXX should i order?Many thx
TK. Posted January 14, 2007 Posted January 14, 2007 6x 24LC512 for pattern and 2x 24LC256 for song and mixer?currently yes. It could be, that I will provide an option for using 64k BankSticks for Songs (32 instead of 16 songs), it would be an easy changeIs´s posible to connect two or more bankstix pcb to the core?yes, but the maximum number of IIC EEPROM devices is 8. They could be located at different PCBs, but each device needs a unique address on the IIC busSo how many 24LCXXX should i order?Just order 8 x 24LC512 (Mixer: only 32k are allocated, but you can use a 64k device which doesn't hurt)Best Regards, Thorsten.
Dauwige Posted January 14, 2007 Author Posted January 14, 2007 thx for the fast reply.Is´s posible to connect two or more bankstix pcb to the core?i mean if it´s possible to switch mecanical between different bankstix pcbs?Will the core recognize the switch?So maybe its possible to have more memory.
TK. Posted January 14, 2007 Posted January 14, 2007 Yes, this is possible. BankSticks can be changed on-the-fly during runtime (hot plugin)Best Regards, Thorsten.
Echopraxia Posted September 21, 2007 Posted September 21, 2007 Is´s posible to connect two or more bankstix pcb to the core?yes, but the maximum number of IIC EEPROM devices is 8. They could be located at different PCBs, but each device needs a unique address on the IIC bus.TK. Does a setup of 8 banksticks affect adding the IIC module to J4 of the core? Will I be only able to install say 6 banksticks and 2 IIC modules?
seppoman Posted September 22, 2007 Posted September 22, 2007 you´ve asked that and been answered with an educated guess just two days ago. Why don´t you just try it out? You can´t damage anything.S
Echopraxia Posted September 22, 2007 Posted September 22, 2007 Don't mean to repost seppoman. I unfortunately don't have alot of free time to study midibox and I though that posting this question here might be good for future midiboxers. I'll shut up and try it when I get the parts :)
TK. Posted September 23, 2007 Posted September 23, 2007 8 BankSticks + 4 MBHP_IIC_MIDI modules connected to the same IIC bus are working fineBest Regards, Thorsten.
