LCD emulator??
Mr modnaR
any other suggestions which don't require a degree in gobbledegook are welcome.  ;D
all i know is perl is some kind of programming language, and these appear to print out the lettering to a website. quite how this happen is magic to me, or possibly gremlins. ahh well, i'll have to fiddle with photoshop i guess. cheers
hehe..... ;D
Had to be careful on this thread, "Read the noob 4 dummies thread" as an answer to what seems like a very unrelated question might seem a bit hostile when it's really not... :)
In hindsight I think we missed a quick opportunity to poke fun at you....  ;D
Best
Smash
lol, yeah it was the last place i'd thought of looking. stupidity knows no boundaries i guess.
*scuffles back to lair, humbled*  ;D
it's not that complicated if you know how to call them.
I don't know if that's also valid for DOS, but in a bash terminal you must type
[tt]./scriptname.pl[/tt] to run it.
or you may try [tt]perl scriptname[/tt]; of course the filepaths have to match.
You may peek into the file itself to lern about parameters you have to pass, but what I saw from these scripts, you may adapt them simply for you needs.
Cheers,
Michael
http://www.pic101.com/mcgahee/
What a nice guy he is! :)
once again stryd, thanks!
./scriptname.pl to run it.
or you may try perl scriptname; of course the filepaths have to match.
Cheers,
Michael
thanks michael, i'll look into how it all works.
perl vx and it doesn´t exist! Is it the path problem?
yes, you got to change the current path before calling this; or submit the whole path;
so in bash it would be either:
[tt]
cd /path/to/perl/script/
perl myscript.pl[/tt]            or use the "shortcut":      [tt]./myscript.pl [/tt]
(cd is for change directory; If I remember right it's the same with DOS)
or [tt]
perl /path/to/perl/script/myscript.pl
[/tt]
If the script provides some output (which should normally be the case; eg. infos on expected parameters), then you should see something...
Cheers,
Michael
Hi
I've just tried one of the script on windows
It can generate all of the screens in .xpm, if the gif convertion is disabled
my $convert_gif = 0;
if I understand correctly, the script needs a conversion program to convert the .xpm to gif:
      system("convert ${output_file}.xpm ${output_file}.gif") && die ("convert failed!\n");
      system("rm ${output_file}.xpm");
*edit: you can find this program here:
http://www.imagemagick.org/script/convert.php
