which modules do I need
shaan_l
hi
been lurking a lot on the forums and learning little bits here and there...and i've gone through the wiki and the hardware pages. I have an "idea" of what I want...but I need to confirm this.
Nothing original here, but I would like to build a controller for ableton.
what i would like is buttons (to load clips/samples), pots (for effects) and led's (to make it look pretty :).
is this right:
for the buttons, i need a DIN
for the pots, i need an AIN
for the led's, i need a DOUT
but for the controller, i'm not sure which I would need as they seem to differ for the modules i would like to use...so if you guys could help me with that, id really appreciate it  :D
Link to comment
Share on other sites
but for the controller, i'm not sure which I would need as they seem to differ for the modules i would like to use...so if you guys could help me with that, id really appreciate it  Cheesy
... you'll also need a CORE  ;D
The type of software you use with your controller can change as you like.
It's transfered to the Core via Midi-Upload. So ut's no problem to change within a minute.
I also think, MB64 is a good start for you.
greets
Doc
Link to comment
Guest
Reply to this topic...
