dj_alm Posted January 18, 2007 Report Posted January 18, 2007 Hello!It's my first post and first of all thanks for this great site!Also it is my first MIDIBos device...At first i'd like to run the core module...so I burned in PIC 18F452 bootloader_v1_2_pic18f452.hex successful. But when I attempted to start it, my MIOS Studio in midi in monitor showed me following strings:00000000820453 ms | [D0 78 00] Channel 1: Channel Pressure value: 12000000000820453 ms | [D0 20 00] Channel 1: Channel Pressure value: 3200000000820453 ms | [D0 00 00] Channel 1: Channel Pressure value: 000000000820454 ms | [D0 01 00] Channel 1: Channel Pressure value: 100000000820455 ms | [D0 3F 00] Channel 1: Channel Pressure value: 6300000000820457 ms | [FF] System Reset00000000822346 ms | [D0 78 00] Channel 1: Channel Pressure value: 12000000000822346 ms | [D0 20 00] Channel 1: Channel Pressure value: 3200000000822346 ms | [D0 00 00] Channel 1: Channel Pressure value: 000000000822347 ms | [D0 01 00] Channel 1: Channel Pressure value: 100000000822348 ms | [D0 3F 00] Channel 1: Channel Pressure value: 6300000000822349 ms | [FF] System Reset00000000824237 ms | [D0 78 00] Channel 1: Channel Pressure value: 12000000000824237 ms | [D0 20 00] Channel 1: Channel Pressure value: 3200000000824237 ms | [D0 00 00] Channel 1: Channel Pressure value: 000000000824238 ms | [D0 01 00] Channel 1: Channel Pressure value: 100000000824239 ms | [D0 3F 00] Channel 1: Channel Pressure value: 6300000000824240 ms | [FF] System Resete.t.c. with period 2 sec.But this is not right request from core module to ulpoad MIOS. And I can't upload MIOS :-(What do you think about this? Can you help me?
doc Posted January 19, 2007 Report Posted January 19, 2007 ... just a first quick thought on that:Did you connect your midi devices in MIOS Studio right? Check this!Do you get the same messages without the core plugged to your PC?If you did all right please follow the steps mentioned here: http://www.ucapps.de/howto_debug_midi.htmland let us know about the results.greetsDoc
dj_alm Posted January 19, 2007 Author Report Posted January 19, 2007 Everything is ok was with my MIDI interfaceI just reburned bootloader and it start work right.Thak you for your help.
