goldie_pl Posted January 21, 2007 Posted January 21, 2007 Hi all,thanks to your help I have now working CORE with LCD, a DIN with 4 buttons on vectorboard connected to it, one AIN (without connected pots yet). I burned a PIC, uploaded MIOS and MB64 app, but cannot get the menu! From start - what I see on LDC:1. MIOS V 1.9c © T. Klose (in two rows)2. AIN DIN DOUT (I know that AIN flickers because of unmuxed pot inputs) 64:42 1o 2o3. When I push the buttons: AIN DIN DOUT 64:42 3* 2o - it changes of course when I push another button (only second column).But - why I just can't see the screens from Tutorial page?I can connect these 4 buttons to another grup of pins on DIN (first 1-4, second 5-8 etc), but tested all of them (1-32) and never saw the nav menu. Why?And - how to disable pots for the time before I connect them physically, because now it's almost not possible to use the buttons (messages from AIN just scroll thru the screen of MidiOX).
doc Posted January 21, 2007 Posted January 21, 2007 Hi,But - why I just can't see the screens from Tutorial page?Which application did you load?And - how to disable pots for the time before I connect them physically, because now it's almost not possible to use the buttons (messages from AIN just scroll thru the screen of MidiOX).You can ground J5 of the CORE (Pins: A0 - A7) after disconnecting any AIN Module.greetsDoc
goldie_pl Posted January 21, 2007 Author Posted January 21, 2007 Which application did you load?ain64_din128_dout128_v1_3.zip - described as "MIOS configured for 64 pots, 128 buttons, 128 LEDs" from this page.You can ground J5 of the CORE (Pins: A0 - A7) after disconnecting any AIN Module.Definitely helped. Now got stable signal. I connected two pots and one joystick (so got 4 pots now) and all of them are working fine.Some photos describing my problem from previous post (I still got it):Booting - everything seems OKApp started - where are menu?Putton #3 pushed - still no menu,the same when I push any other buttons.It seems like some kind of debugger, not an app for me - but i may be wrong.Got no idea what's happening. Can somebody help?Below is monitoring buttons report from MIDI OX:TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT Opened MIDI InputOpened MIDI Output000010B4 9 10 90 00 7F 1 C -1 Note On (BUTTON #1 PUSHED)00001174 9 10 90 00 00 1 C -1 Note Off (BUTTON #1 RELEASED)0000202F 9 10 90 01 7F 1 C#-1 Note On (BUTTON #2 PUSHED) 000020E1 9 10 90 01 00 1 C#-1 Note Off (BUTTON #2 RELEASED)0000258D 9 10 90 02 7F 1 D -1 Note On (BUTTON #3 PUSHED) 0000265F 9 10 90 02 00 1 D -1 Note Off (BUTTON #3 RELEASED) 0000287C 9 10 90 03 7F 1 Eb-1 Note On (BUTTON #4 PUSHED) 0000291F 9 10 90 03 00 1 Eb-1 Note Off (BUTTON #4 RELEASED) So what is this - a KEYBOARD?Little off topic - special edition of "bomb in cable factory" - my PIC Burner!I know it can sounds strange' date=' but it works perfectly.
doc Posted January 21, 2007 Posted January 21, 2007 ain64_din128_dout128_v1_3.zip - described as "MIOS configured for 64 pots, 128 buttons, 128 LEDs" from this page.OK. This is a test application.Everything is fine so far. This app is for debugging.But - why I just can't see the screens from Tutorial page?You'll have to load another app instead of the test application. If you want a midibox64you'll have to upload (via Midi) the following app:http://www.ucapps.de/mios/midibox64_v2_4.zipThen you'll get the desired screens.Don't forget to ground unused AIN-ports or you still will get wild messages.greetsDoc
goldie_pl Posted January 21, 2007 Author Posted January 21, 2007 You'll have to load another app instead of the test application. If you want a midibox64you'll have to upload (via Midi) the following app:http://www.ucapps.de/mios/midibox64_v2_4.zipThen you'll get the desired screens.Don't forget to ground unused AIN-ports or you still will get wild messages.greetsDocTHANKS DOC. Everything works perfect!Now it's time to plan the case and front/top panels, placing buttons and pots and other stuff. I want to use encoder instead left/right buttons. I thought about placing touchpad on top panel, but not for MIDI, but as pointing device for connected PC, so I ordered 2 from damaged laptops (price was very low - about 4 EU each) - if I get them to work, I will share photos and specs with you.Once again: Thanks all!
