Just finished the sid module.....
And I got no sound (With logic enviroment). :(
How should I check if the CORE moudule ?
Or if the 8580 chip works ??? :-/ >:(
I check If I get 9V and 5V and that seems to work...
Hope someone can help me...
Christoffer
Hi Christoffer,
under http://www.ucapps.de/mbhp_prg.html you will find a test program for the SID module which starts with a chort at power-on. On this way you can ensure that the Core module can access the SID and that the Audio Out is working. Thereafter you can use the same program to test the MIDI-In (a saw sound should be played on Note events). If this works, you can continue with the original MIDIbox SID firmware
MY SID IS WORKING!!!!! ;D
It was the ic socket that have no connection to the Sid chip only on the 9V and the 5V :-/
Think I was meen to it when i checked it...
Thanks Love this!!! ;D
Christoffer
