Geerinckx Posted February 3, 2007 Posted February 3, 2007 Hi guy'sStill buzzy on my midi box! Ill drop some pic's soon but i have still some questions1) Can I use a bankstick with MidiBox 128??2) When i wonna connect a Midibox 64 & a midibox 128 to an LTC module i have to use the MidiBox Link! But where can i adjust this in de assamber files?3) i Still can't convert a ini file to a sysex file i follow al the instructions but i always get an error:C:\Documents and Settings\Gert Geerinckx\Bureaublad\pic18f>perl mk_syx.pl midibox64.iniBareword found where operator expected at mk_syx.pl line 0, near "s/Perl/site/lib"syntax error at mk_syx.pl line 0, near "'E:/Programma's/Perl/site/"Bad name after pl'.C:\Documents and Settings\Gert Geerinckx\Bureaublad\pic18f>What am i doing wrong?4) When i'm using different banks i can assign the same button to different Midi notes. Am I correct??GreetingsGert
TK. Posted February 5, 2007 Posted February 5, 2007 Hi Gert,no, MIDIO128 doesn't support BankSticks, it's a very dumb application which only allows a single configuration.For MIDIO128, MIDIbox Link can only be enabled within the initialisation file (download the mk_midio128_syx package)The error message is very strange, I never saw this before.What is "s/Perl/site/lib"?Which perl version are you using?> 4) When i'm using different banks i can assign the same button to different Midi notes. Am I correct??for MB64/MB64E: yesBest Regards, Thorsten.
Geerinckx Posted February 5, 2007 Author Posted February 5, 2007 Hi Tk,Thx for the quick reply!What is "s/Perl/site/lib"?Not a Clue what it is!Which perl version are you using?I followd the instructions in the README file:o DOS/Windows Users should install ActivePerl, which is available at the following site: http://aspn.activestate.com/ASPN/Downloads/ActivePerl/index/ Get the .msi package and follow the installation instructions (Win98 users have to install the Microsoft Windows Install 1.1+, too) To start the script just open a command window and type (i.e.) perl mk_midio128_syx.pl midio128.ini -> the resulting syx file is named "midio128.syx"The Perl virsion = 5.8.8.820Is MB64 easy to modify to be enable to reconize 128 DIN's?I only need 192 DIN's and 64 AIN's I have 2 cores, 6 DIN's, 2AIN's & LTC moduleIt would be great if i can add 4 more banks/desk's to it so i can control 768 Digital parameters!GreetingsGert
goldie_pl Posted February 5, 2007 Posted February 5, 2007 I'm just guessing, but: try to move all files into the directory with short name and reinstall Pearl into default dir. Got the same problem with other soft, the reason was the script doesn't recognise longer/spaced filenames.
Geerinckx Posted February 5, 2007 Author Posted February 5, 2007 Hi Goldie_plYes!! ;) Now it works :-*, Reinstalled Perl on de default dir "C:" and now i can execute the script! Thank You Verry Much ;D :DAnybody a idee, about modifying MB64 to reconize 128 DIN's and stil have the Bank possibility?Or may i better use MB64e:?In priniciple 128 digital inputs are available, every button allocates one input, every rotary encoder allocates 2 inputs.....GreetingGert
Geerinckx Posted February 14, 2007 Author Posted February 14, 2007 Me Back again!Ive been Reading, reading, reading......But still no idea how i can modify MB64e or MB64 to reconize 128 buttons but still have te opportunity to do this with different banks...Annybody an idee???????GreetingsGertps I'l post some pic's soon of the cores with the dins and ains.....
