Hi guy's
Still buzzy on my midi box! Ill drop some pic's soon but i have still some questions
1) Can I use a bankstick with MidiBox 128??
2) When i wonna connect a Midibox 64 & a midibox 128 to an LTC module i have to use the MidiBox Link! But where can i adjust this in de assamber files?
3) i Still can't convert a ini file to a sysex file i follow al the instructions but i always get an error:
C:\Documents and Settings\Gert Geerinckx\Bureaublad\pic18f>perl mk_syx.pl midibo
x64.ini
Bareword found where operator expected at mk_syx.pl line 0, near "s/Perl/site/li
b"
syntax error at mk_syx.pl line 0, near "'E:/Programma's/Perl/site/"
Bad name after pl'.
What am i doing wrong?
4) When i'm using different banks i can assign the same button to different Midi notes. Am I correct??
Greetings
Gert
Hi Gert,
no, MIDIO128 doesn't support BankSticks, it's a very dumb application which only allows a single configuration.
For MIDIO128, MIDIbox Link can only be enabled within the initialisation file (download the mk_midio128_syx package)
The error message is very strange, I never saw this before.
What is "s/Perl/site/lib"?
Which perl version are you using?
for MB64/MB64E: yes
Hi Tk,
Thx for the quick reply!
Not a Clue what it is!
I followd the instructions in the README file:
o DOS/Windows Users should install ActivePerl, which is available at the
    following site:
        http://aspn.activestate.com/ASPN/Downloads/ActivePerl/index/
    Get the .msi package and follow the installation instructions
    (Win98 users have to install the Microsoft Windows Install 1.1+,
    too)
    To start the script just open a command window and type (i.e.)
        perl mk_midio128_syx.pl midio128.ini
        -> the resulting syx file is named "midio128.syx"
The Perl virsion = 5.8.8.820
Is MB64 easy to modify to be enable to reconize 128 DIN's?
I only need 192 DIN's and 64 AIN's I have 2 cores, 6 DIN's, 2AIN's & LTC module
It would be great if i can add 4 more banks/desk's to it so i can control 768 Digital parameters!
Greetings
Gert
I'm just guessing, but: try to move all files into the directory with short name and reinstall Pearl into default dir. Got the same problem with other soft, the reason was the script doesn't recognise longer/spaced filenames.
Hi Goldie_pl
Yes!! ;) Now it works :-*, Reinstalled Perl on de default dir "C:" and now i can execute the script! Thank You Verry Much ;D :D
Anybody a idee, about modifying MB64 to reconize 128 DIN's and stil have the Bank possibility?
Or may i better use MB64e:?
In priniciple 128 digital inputs are available, every button allocates one input, every rotary encoder allocates 2 inputs.....
Greeting
Gert
Me Back again!
Ive been Reading, reading, reading......
But still no idea how i can modify MB64e or MB64 to reconize 128 buttons but still have te opportunity to do this with different banks...
Annybody an idee???????
Greetings
Gert
ps I'l post some pic's soon of the cores with the dins and ains.....
