d2k Posted April 22, 2003 Report Share Posted April 22, 2003 Hi...okay, i tracked down the problem - for some reason the LED for the midi out status will now only work if i bypass the 470ohm resistor, tho very occasionally it'd flicker and/or work a bit when connected as normal after the resistor - weird???No matter tho, i just have brighter midi out LED is all...BestDan Quote Link to comment Share on other sites More sharing options...
TK. Posted April 22, 2003 Report Share Posted April 22, 2003 Yes, really weird. Must be a problem with the bridge between pin 2 of the 74HC00 and the resistor... if not: exchange the IC by another 74HC00 to check if it still worksBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
