any ideas
kris
hello
    im trying to get my first midi-box up and running its one of the first all in one boards and one of the old chips
anyway it boots fine all of the buttons sliders etc are working fine but ive attached it to a m-audio midisport and connected to my xp box with midi-ox running and i get no signal
ive checked and re-checked the wiring thru from midi out to midi in on midi sport checked the usb leads etc
this box has  been in storage but worked fine before and hasnt got damp etc i removed the midi to usb before storage and connected another now
its got me baffeled and any input on gotos is going to be gratfully received the only think i can think of is the 6n 138 opto coupler but this is on midi in not out so shouldn't
effect the midi out
thanks kris
Link to comment
Share on other sites
did you check to make sure midiox is configured properly?  i think you have to set which input(s) to monitor.
try another piece of midi gear to your midisport.  buying a $100 casio or yamaha keyboard from best buy is always an option if you're desperate.  they have a pretty good return policy :P.  that'll tell you if it's the midisport or your midibox that doesn't work.
even if you're not sure what's causing the problem, you should be able to find out pretty easily which device doesn't work.
Link to comment
thanks for the reply
midi-ox is configured ok it gets signals from my other midibox midi-sport combination
another midi input thru the midi-sport is a good idea
cant help wondering about the optocoupler theres away to test them with a meter but i cant remember how oh well
kris
Link to comment
  all sorted it was a crossed wire from midi-box board to usb-midi interface
  i think really it was upset at being in storage so just needed the right amount of attention before its going to play again but now its ready hurrah
Link to comment
Guest
Reply to this topic...
