Guest dendy Posted April 24, 2003 Posted April 24, 2003 core works ok, on start up sends sysex F0 00 00 7E 40 00 01 F7.pots sends only 1 values when moving...tested with 1 single pot connected directly to core, unused PIC inputsconnected to ground, 2 versions of mios - configured for 64 pots and configured for 1 signle pot (downloaded from download section) - and the same result... while moving pot, core send only one value at the begin of pot's range (works like button).sorry for poor english
Guest dendy Posted April 24, 2003 Posted April 24, 2003 when connected thru AIN the result is same for every pot... every pot sends another value but every sends only one at the beginnig of pot range...
TK. Posted April 30, 2003 Posted April 30, 2003 Hi Dendy,it seems that your pots are not connected correctly. Maybe the power lines at the outer pins... check also this schematic:http://www.ucapps.de/mbhp/mbhp_ainx4_64pots.pdfBest Regards, Thorsten.
