ultra Posted March 1, 2007 Posted March 1, 2007 hi,i'm trying to test out the buttons i wired up for the first din module. this is the F1-F4, menu, select, and exit buttons.when starting from first loading it, this is what i see when i click each button:F1:save patterna1->a1 (all)F2:record track: 1step: 1F3:muted tracks:ooooooooooooooooF4:muted tracks:****************menu:nothingselect:l trck p1 posa *234 a1 1/16exit:midiboxseq v2.4cdisplayare these the right screens?drew
monokinetic Posted March 1, 2007 Posted March 1, 2007 hiya,I would recommend uploading the MIDI128 app to test DINS, its on the mios download page.Once you have it uploaded the screen shows you which shift register and which pin is being read. This process saved me hours of soldering debugging :)BestDave
ultra Posted March 1, 2007 Author Posted March 1, 2007 unfortunately this didn't do it. i loaded the closest thing to what you said (MIDIIO128) and that gives me note names when i press buttons. i also tried srio_interconnection_test_v1 and nothing happened when i hit buttons.
moxi Posted March 2, 2007 Posted March 2, 2007 hi,for the "F(x)" buttons, it's okay you see the good screen.The menu button act toguether with GP buton, so it's normal nothing happen if you only press it...for the select buton I think it's normal too if your are not in a particular menu.exit ok tooyou're on the right way ;)
ultra Posted March 2, 2007 Author Posted March 2, 2007 thank you moxi. i would hate to build up the rest of them without knowing if i was doing it right.i'll be done soon :).drew
