thetimboroni Posted March 3, 2007 Report Posted March 3, 2007 Alright, I'm really really trying to figure this out. I have read many posts where people have had problems uploading MIOS and their problems have been solved so i'm hoping for the same!The first page I looked was the debug page. I have done tests and the only things I'm sure of are that the optocoupler is fine (b/c i ordered two more since people had that problem often), that my polarity is fine on the midi ports, and taht my resistors in Test 1 are fine.Now I'm on Test IN3. I'm not exactly sure what this test tells me. When connected to 26 and 31, the LED is lit. However I don't understand what this means:"So long as single MIDI events are recieved, you won't notice a difference, but with a continuous SysEx stream the LED should begin to flicker."How do I get a continuous SysEx stream? Is that simply the dump request from the Out every 2 seconds? If so, then the LED does not flicker, so what does that tell me?Like I said, I'm really just confused as to what this test is supposed to tell me.Please helpThanks,tim.
stryd_one Posted March 3, 2007 Report Posted March 3, 2007 Athe only things I'm sure of are that the optocoupler is fine (b/c i ordered two more since people had that problem often)Never assume it's working just because it's new.How do I get a continuous SysEx stream?Try a continual stream of midi CC's, that'll work too - just go crazy on your modwheel.
thetimboroni Posted March 4, 2007 Author Report Posted March 4, 2007 ok i still get no flicker. now what does that tell me?
TK. Posted March 4, 2007 Report Posted March 4, 2007 Maybe the pins of the MIDI In socket are swapped, or the LED is connected the wrong way (cathode = short leg has to be connected via a 220 Ohm resistor to ground)Best Regards, Thorsten.
thetimboroni Posted March 4, 2007 Author Report Posted March 4, 2007 Well I've got the midi ports mounted straight to the pcb so there's no room for polarity error. (right?)On another note:I'm trying the loopback test (shorting the Rx/Tx pins), and don't think I'm doing it right. When I take the PIC out, there is no SysEx request from the out... therefore MIOS studio doesn't recognize the core... so how am I supposed to test for loopback?
thetimboroni Posted March 4, 2007 Author Report Posted March 4, 2007 YAY!I played my synth this morning at church, and when I went to plug in my Midiman 1x1 I got nothing. So I ran back home and got and old midi cable that plugged into my game port. it worked. "Hm. Maybe this is the root of my problems w/ my MIOS controller..." So I just got home... first try MIOS uploaded! Thanks for all the help and troubleshooting pages! Even though it was simple there were a few things wrong I had to fix along the way (i.e. a reversed Diode, not enough voltage across the PIC...).Now I'm gonna cross my fingers on the application.
thetimboroni Posted March 4, 2007 Author Report Posted March 4, 2007 ok new problem...While uploading MIOS I had no other modules connected to the core. After I uploaded MIOS to the PIC, I soldered all the other PCBs to the core. Now when I give power to the core, MIOS does not come on (I get no initial SysEx message), and IC3 is extremely hot. Most likely a bad sign.Why would it be hot?Thanks,tim.
lylehaze Posted March 4, 2007 Report Posted March 4, 2007 IC3 gets hot if there's too much current.Something is connected wrong, possibly plugged inbackwards. Or you have too much load on theregulator.I'd grab a meter and check voltage and polarity at every chip.Good Luck,LyleHaze
thetimboroni Posted March 4, 2007 Author Report Posted March 4, 2007 Well I'm only getting 5v at J1 then around 3v at IC3 and nothing at J2....
lylehaze Posted March 5, 2007 Report Posted March 5, 2007 You mentioned that the problem started when you connected all the boards. If you unplug all the boards the problem will probably go away(give it a few minutes to cool down).Then you could re-connect boards until the problem returns.Of course, never connect or disconnect any boards with the power on. Turn it off to make changes.That should help you to narrow it down a bit.LyleHaze
