dreuf Posted March 17, 2007 Posted March 17, 2007 hello, you say "The TL074s can be alternatively powered from +/-5V to +/-18V."So, is it possible to make an OPL3 Module with +/-5V instead of +/12V?If yes, what modifications should i do to the OPL3 Module?thanks!
TK. Posted March 17, 2007 Posted March 17, 2007 Hi,there are no modifications required for +/- 5V, the TL074 works fine in this voltage range.Best Regards, Thorsten.
/tilted/ Posted March 26, 2007 Posted March 26, 2007 Hi.I may be way out of line here, but from my experience, opamps such as the TL074 work much better with higher supply rails.You can absolutely use +/-5V rails, but be aware the noise and distortion figures may be compromised.Good luck!Matt
vedge Posted March 26, 2007 Posted March 26, 2007 On a related note, anyone knows of a _small_ =+12/center/-12 transfo with enough amperage to drive the three opamp, thatwould FIT inside a 1U rack??? Ive got two of them from different manufacturers, but they are way too big (one is 2A and the other 1A)Cheers
AndrewMartens Posted March 26, 2007 Posted March 26, 2007 I was lazy (read as: sick of perfboarding), so I picked up this kit: http://www.rpelectronics.com/English/Content/Items/CK342.aspAnd the recommended transformer:http://www.rpelectronics.com/English/Content/Items/640-1803.aspIIRC it's short enough to fit in a 1U rack, but I would have to go home and measure it to make sure (it's sitting in a drawer right now, waiting for me to have more free time). This is only going to be enough juice to handle the +/-12V easily, but possibly not the +5V if you're using a backlit LCD. And as always, remember to use fuses, etc.
vedge Posted March 27, 2007 Posted March 27, 2007 I was lazy (read as: sick of perfboarding), so I picked up this kit: http://www.rpelectronics.com/English/Content/Items/CK342.aspAnd the recommended transformer:http://www.rpelectronics.com/English/Content/Items/640-1803.aspIIRC it's short enough to fit in a 1U rack, but I would have to go home and measure it to make sure (it's sitting in a drawer right now, waiting for me to have more free time). This is only going to be enough juice to handle the +/-12V easily, but possibly not the +5V if you're using a backlit LCD. And as always, remember to use fuses, etc.Wow, if i had known, i would have bought this pre made kit too!Id be currious on the dimensions of the transformator, ill wait for the results.Im using a separate transfo for the normal MB operations.
AndrewMartens Posted March 29, 2007 Posted March 29, 2007 IIRC it's short enough to fit in a 1U rack, but I would have to go home and measure it to make sure (it's sitting in a drawer right now, waiting for me to have more free time). This is only going to be enough juice to handle the +/-12V easily, but possibly not the +5V if you're using a backlit LCD. And as always, remember to use fuses, etc.Well, it's a pleasantly small transformer, smaller than I remembered. 36mm tall, that is about 1.4" high, which should still give you enough clearance to put it into a 1U rack case.
vedge Posted March 29, 2007 Posted March 29, 2007 Well, it's a pleasantly small transformer, smaller than I remembered. 36mm tall, that is about 1.4" high, which should still give you enough clearance to put it into a 1U rack case.What about the 12VCT / 300mA Transformer from that same dealer:http://www.rpelectronics.com/English/Content/Items/640-1203.asp12VCT should be enough to drive a 7912 and a 7812? and wouldn't generate as much heat as the18VCT.. in any case ill order both of them and report.Thanks again for the dimensions!
