hi, I build a Step A control surface for my sid with push buttons.  Everything is working fine except that half the time I push my increase or decrease button, the value increase (or decrease) by more than one...  usually two and sometimes three.  Is there a parameter I didn't see in my .asm file that can fix this or is it just because I have cheap push button?
thanks
Normally the buttons are debounced by software.
There are more possibilitys than bad knobs.
If I remember right there is a value to change the debounce behaviour.
Have a look in the source code...maybe you'll find it.
You also can try to debounce a bad knob with a resistor and a small cap (10 ..100 nF).
greets
Doc
