I know it's not chiristmas....... :P
QBAS did me some superb code for a 9 by 18 matrix. However, I want to add other function to the code (as one does), but QBAS is an assembly man, and I'm not.
Am I right in saying that the main.asm file in the assembly version should become the mios_wrapper.asm in the sdcc skeleton, and just copy all associated files into the mios_wrapper folder  OR am I just as stupid as George Bush? ::)
Project nearly finished, so photos etc on the way.....
Mark.
George Bush isn't stupid and neither are you... But your guess was about as right as he is a good speaker  ;D
You'll need to wrap the ASM that qbas sorted out into the main.c, using techniques like those at the How to mix C and ASM wiki page, or include the ASM file in your C project, using techniques like the using assembler in C - question about _ in front of macro names post :)
Feel free to post/PM/email me for a hand.
erk-- a lot of asm- lost, totallty lost.
In the ucaaps there are great example blocks of code, like how to send cc values when a pot has been moved. Is there an ASM version of this anywhere. All I want to do is assign 20 slide pots set values, and never have to touch them again.
AAny ideas?
Try this mate. As stolen from mb64 like a cowardly pirate, yargh.
;;  This function is called by MIOS when a pot has been moved
;;  Input:
;;     o Pot number in WREG and MIOS_PARAMETER1
;;     o LSB value in MIOS_PARAMETER2
;;     o MSB value in MIOS_PARAMETER3
USER_AIN_NotifyChange
	;; convert 10-bit value to 7-bit value
	rrf	MIOS_PARAMETER3, F	; value / 2
	rrf	MIOS_PARAMETER2, F
	bcf	MIOS_PARAMETER2, 7	; clear 8th bit
	;; now: pot number in MIOS_PARAMETER1
	;; 7-bit value in MIOS_PARAMETER2
	;; CC Ch 0
	movlw 0xB0
	call        MIOS_MIDI_TxBufferPut
	;; CC# = Pot#
	movf MIOS_PARAMETER1, W
	;; CC Value = Pot Value
	movf MIOS_PARAMETER2, W
