TK. Posted April 16, 2007 Report Posted April 16, 2007 If you are planning to create a frontpanel for your MIDIbox SID V2 ("Step A", "B" or "C" stage), please consider that the purpose of the Link/CC and Edit button has been changed. This mainly affects the lablingthe LINK button will get the purpose of a SHIFT button. In addition, it displays a special configuration page, which for example allows you to switch between left and right SID channelthe CC button is used for "Page Up" (increments OSC/LFO/ENV/MOD/TRG/KNB)the Edit button is used for "Page Down" (decrements OSC/LFO/ENV/MOD/TRG/KNB)SHIFT+CC and SHIFT+EDIT still switch the CC/Edit function like before - this means: the two LED labels are still valid!in the OSC section, the "Arpeggiator" label should be renamed to "Phase"The Page Up/Down buttons are just a new feature which save you from scrolling to the left end of a menu page in order to select a different oscillator/LFO/ENV/... etcA MBSID with the minimal "Step A" control surface still allows full access to all parameters, but adding a Shift/Page Up/Down button is strongly recommented for faster usageBest Regards, Thorsten. Quote
rutgerv Posted May 19, 2007 Report Posted May 19, 2007 That's interesting news! Does it mean that the new step A surface will require an extra DIN and DOUT module?Greetings,Rutger Quote
TK. Posted May 19, 2007 Author Report Posted May 19, 2007 Yes, you need an additional DIN (so: DINX2 instead of DINX1, but I guess that you will use a DINX4 anyhow?)DOUT is not required for a "Step A" CSBest Regards, Thorsten. Quote
