bosone Posted May 13, 2007 Posted May 13, 2007 when you are using a 32 step pattern (length=32), what about an automatic "switch" on the display as the step goes after the number 16?i mean:on the display it is always show either the 1-16 OR the 17-32 part of the 32 step pattern.if you have to make some change on the "other part" of the patter (17-32 when you are displaying 1-16 and viceversa) you have to switch the display with the appropriate button.it could perhaps be useful that this change (1-16 -> 17-32 -> 1-16, etc) is handled automatically, so that you always see the part of the pattern that it's playing, and you just edit the appropriate steps as the pattern proceeds...what do you think?
TK. Posted May 13, 2007 Posted May 13, 2007 I tried this some time ago, but the handling was so bad, that I skipped this feature.Such an "auto-follow" is especially *not* useful for editing, because when you move an encoder at the same moment where the sequencer automatically switches from one to another page, you will modify the wrong step. A solution for this issue would be a special detection, which ensures that the page is not switched while you move an encoder, but this is complicated and would blow up the code too much (-> high danger for new bugs)Best Regards, Thorsten.
basix Posted June 27, 2008 Posted June 27, 2008 if multi color leds were used, one could see it as follows:1-16 green17-32 red33-48 orange = 2 colors lit (if available)...
stryd_one Posted June 27, 2008 Posted June 27, 2008 I don't think that would bypass the problems TK mentioned.
