thestruggler Posted May 21, 2007 Posted May 21, 2007 hi,This is probably one of the dumbest questions but I seem to be a bit lost. I am not sure which pin on the potentiometer or sliders go where on the AIN. The sliders have 4 pins labeled 1 -3 (two of them being labeled 2). The pots just have three pins with no numbers? How can i test which one is which? Any link to info would be appreciated.Thanks
Sasha Posted May 21, 2007 Posted May 21, 2007 Outer pins should go to "+" and "-" and inner pin to AIN input
TheAncientOne Posted May 21, 2007 Posted May 21, 2007 In the type you mention, 2 is usually the slider. 1 and 3 are the ends. A quick check with the ohms range of a testmeter will sort it out. In this case, 2 would go the the AIN, and 1 and 3 to positive and negative, depending upon which end was which.HTHMike
thestruggler Posted May 22, 2007 Author Posted May 22, 2007 Hi,Thanks for your replies!Found an article that others might also find useful. http://sound.westhost.com/pots.htmWith regards to the faders with 4 pins and two of them being labelled pin 2... do i connect them to each other?
TheAncientOne Posted May 23, 2007 Posted May 23, 2007 With regards to the faders with 4 pins and two of them being labelled pin 2... do i connect them to each other?Check with a testmeter - they are usually already connected.Mike
