PIC bootloader problem [SOLVED]
vattern
Hi there.
I have a core board, which if I load the MIDI echo hex file, echo very nicely whatever I send it.
However, if I load the bootloader : bootloader_v1_2b_pic18f452.hex using winpic, I keep getting the following messages on my input :
00000001620872 ms | [90 78 20] Channel 1: Note On C9 velocity: 32
00000001620873 ms | [C8 01 00] Channel 9: Program Change no: 1
00000001620874 ms | [C8 3F 00] Channel 9: Program Change no: 63
00000001620874 ms | [FF] System Reset
00000001620874 ms | [A0 78 20] Channel 1: Aftertouch C9 pressure: 32
00000001622765 ms | [C8 01 00] Channel 9: Program Change no: 1
00000001622766 ms | [C8 3F 00] Channel 9: Program Change no: 63
00000001622766 ms | [FF] System Reset
00000001622766 ms | [A0 78 20] Channel 1: Aftertouch C9 pressure: 32
I expect the sysex message, but dont get it.
Any pointers ?
Thanx
Thys
Thanks for the quick response Thorsten
Dumb question , but what should the bits be set to ? (Default config)
I have two config words I can set. when I load the code into the programmer, they show up as FEFF and FFF3.
Is this correct ?
Thanks
Thys
no, these are the flags for various hardware options (e.g. oscillator selection, brownout voltage, code protection). These two words should never be changed.
The ID field is a number with 16 digits (8 bytes). It is "all-1" after erase, and if it won't be programmed, you will notice exactly the described effect.
I just have downloaded WinPIC and searched for a possibility to change the ID field. It seems that the GUI doesn't allow this. But under "Device->Program ID locations" you can program it, propably with the values which are embedded in the .hex file (and in this file I've written the all-zero header)
So, just try this function, hope that it helps.
If not, the "TEST SW2" workaround of the MIDI troubleshooting page could help
