The III Man Posted August 8, 2007 Posted August 8, 2007 Hi, a newbie wiring question.When wiring up pots onto my AINS I know I have to link each to ground and +ve as well as to an input pin, however is it essential that each pot is linked to the Vs & Vd corresponding to where on the AIN it is wired to or can you use Vs & Vd freely. I.e can I ground and wire to +ve a whole load of pots in series from one Vs and Vd?Hope this makes sense. The reason I ask is due to lengths of wires in my box etc.ThanksToby
stryd_one Posted August 8, 2007 Posted August 8, 2007 I.e can I ground and wire to +ve a whole load of pots in series from one Vs and Vd?Nope, pots in parallel only. If you haven't seen the schematic:mbhp_ainx4_64pots.pdfYou might have also missed this important notice:auaimbctg.pdf ;)
The III Man Posted August 8, 2007 Author Posted August 8, 2007 The reason I am asking is because I have connected my core and I am getting loads of signals coming out. I was aware I had to ground all unused AIN inputs and have done - thats to Vs right?The problem is I started planning to wire one way and finished another. The result is I have 8 pots wired as below to a Vs & Vd, however they are not necessarily grounded the the same Vs & Vd as the middle wire goes back to. (Sorry I dont know how to explain it more clearly, the 2 diagrams below should make it more simple).sooooo...So overall my wiring is definitely wrong according to the schematic, I was just kind of hoping the way this worked meant that Vs and Vd were a constant and thus it doesnt really matter which one any row of pots are wired to?ThanksTobyPs. I know I should have done it right the first time!
MTE Posted August 9, 2007 Posted August 9, 2007 You must wire all VSS and VDD from each 8-pair together....look here ;)Regards
stryd_one Posted August 9, 2007 Posted August 9, 2007 I searched for an hour for that image, and found squat :-[ LOLstar-like, starlike, star like... here...the wiki....google... nothing.Thanks MTE :)
The III Man Posted August 9, 2007 Author Posted August 9, 2007 Awesome, will try this out tonight. Hoping its the solution to my issues, got to say I hadn't realised that was the case at all.thanks for your help alltoby
MTE Posted August 9, 2007 Posted August 9, 2007 I searched for an hour for that image, and found squat Embarrassed LOLstar-like, starlike, star like... here...the wiki....google... nothing.Thanks MTE ;DThis you will find at the midibox64-walkthrough -> http://www.midibox.org/users/tor_arne/midibox64_walkthrough/index.html -> soldering pots & buttons / soldering everything elseI searched 1 hour too (months ago) so I putted this into Wiki -> Troubleshooting ;)P.S.: searching for "starlike" at Wiki brings you to the section, cant understand why u dont have found it...
stryd_one Posted August 9, 2007 Posted August 9, 2007 http://www.midibox.org/usersSome hidden treasures there ;)
The III Man Posted August 14, 2007 Author Posted August 14, 2007 Hi,I am still having issues with my AINS and I dont know what is going on. I am getting lots of erroneous signals. I know why this might be the case however shouldnt this stop completely if I link all of J5A and J5B's A0...A7 pins to Vs? WOuldnt that ground them all meaning I should get no output from my AINS at all? For some reason that is not happening.Also I have a query re Smash's AINS and wiring. To provide the +5V and ground for my pots should I use the Vs and Vd from eachs 4051 section or do I use J7? I had thought that the Vs and Vd pins on each section were the way to go but I have read something elsae that has confused me on this?Its irritating cos I'm almost there, all boards are built and soldered however when I boot up I am getting loads of extra midi signals from somewhere? Am i right in saying I don thave to ground the DINS to stop erroneous signalsthanks for your helptoby
DavidBanner Posted August 15, 2007 Posted August 15, 2007 shouldnt this stop completely if I link all of J5A and J5B's A0...A7 pins to Vs?yes it should!Vs and Vd from eachs 4051 section or do I use J7I've used the ones from the 4501 DIL header, but you should be able to use the J7 pins too.Its irritating cos I'm almost there, hang in there dude, you'll get there...
The III Man Posted August 21, 2007 Author Posted August 21, 2007 And the quest goes on!I have rewired and tested connections and have been going mad. All seems to be fine and voltage is getting to the chips and responding to the pots correctly however I haven't been getting a signal on midi ox for lots of my pots.I then (after about 5 days) have realised that the pots start to work if I turn them all the way to +va and then to - ve, or at least most do. Can anybody tell me why this might be the case? Its exciting because things are staring to work, but very odd?thankstoby
midiboxxer Posted August 21, 2007 Posted August 21, 2007 Souns like a "software problem".In the midibox menü, there is a menüpoint called PotMode ->Pot BehaviourIt sounds like you have changed it from normal mode to snap mode. Snap Mode (Soft-Overtake): When you adjust a knob in Snap Mode, the original setting determines the value until the point where the movement of the knob passes beyond this position. In other words, the parameter does not jump to the value as in Normal Mode. However, keep in mind that your adjustments have no effect on the parameter until the knob "snaps" on at the position equivalent to the original parameter. In SNAP mode, an right arrow symbol appears instead of the parameter bar. It indicates in which direction the knob must be turned to exceed the current parameter value. Arrow Left implies the value is lower. The parameter bar appears when the value is "snapped". With the mk_syx skrypt (http://www.ucapps.de/howto_tools_mbsyx.html) you can change the pot behaviour if you havent got an lcd display and menü buttoms to do it directly.GreetingsMarkus
stryd_one Posted August 22, 2007 Posted August 22, 2007 I then (after about 5 days) have realised that the pots start to work if I turn them all the way to +va and then to - veWow you must've been turning that knob really slowly!! ;D
