matoz Posted August 10, 2007 Posted August 10, 2007 Hello all, I have a problem: Seq v2 worked very well, yesterday evening, I install version 3 with pic 4620 and 2 modules IIc. And there, I have almost all Led who start to flicker in a strange way and can' t sending a sequence in Sid. However, by defect, the piste1 wrote in the seq which sends a bit on channel 1. The sid does not receive anything. however, on screen and DIN, I have access to all the functions, and it seem to be very good… Moreover, I would like to announce a small inaccuracy on module IIc on mbhp_iic_midi_v3.gif, the flat part of Led should indicate - and not +, which was a source of error…
stryd_one Posted August 10, 2007 Posted August 10, 2007 If you put the 452 back in there does it work OK?Did you add the pull-up resistor (R12) for the IIC modules?Have you performed the midi troublehooting?Did you try re-uploading MIOS and the seq application?
TK. Posted August 11, 2007 Posted August 11, 2007 I remember, that last time a user reported such an issue, he used an older MIOS Studio version which doesn't upload the complete application.So, please make sure that you are using MIOS Studio v7.5 or later.IIC_MIDI, shown LED polarity in PCB overview pic: will be fixed soonBest Regards, Thorsten.
matoz Posted August 11, 2007 Author Posted August 11, 2007 thanks for answers :)If i put 452 back, it works very well.I added the pull up resistor for IIc.I think i founded the problem: IIc' ID are all 00, i saw we must change Id of first IIc to 10. I tryed to change it but no results: IN&OUT of PC to IN&OUT of IIc Midi events go out by midi out of core.Now i have the following problem since seqV2 to V3 and back to V2:Sid' s Led sometimes flicker (less than seq, just a little). sound is correct.
