mat_s Posted August 24, 2007 Posted August 24, 2007 Hi, i am building a sid v2, with 1 core and 2 sids.only ! core, so i don't really need the CAN connection.so my question is: could i connect the LCD in 8bit (using all the pins on core J15) instead of 4bit, since i don't need CAN ?in a previous thread i read about a compile option in mios.h#if PIC_DERIVATIVE_TYPE == 4 LIST P=PIC18F4685, R=DEC #include <p18f4685.inc> #define PIC_DERIVATIVE_CODE_SIZE 0x18000 #define PIC_DERIVATIVE_RAM_SIZE 0xd00 #define PIC_DERIVATIVE_EEPROM_SIZE 0x400 #define PIC_DERIVATIVE_IRQ_WORKAROUND 0 #define PIC_DERIVATIVE_T08BIT_INVERTED 0 #define PIC_DERIVATIVE_SET_LCD_4BIT 1 #endif i guess i would need to change PIC_DERIVATIVE_SET_LCD_4BIT to 0 ?any chance that it could work ? or am i having the wrong idea ?thanks!(oh, btw i wonder if my lcd is a pled type ? i would say no, but i am not sure. i bought that one:http://character-lcd-lcds.shopeio.com/inventory/details.asp?id=1143&cat=Lcds&sub=Character%20Lcd)
Wilba Posted August 24, 2007 Posted August 24, 2007 The "compile option in mios.h" is for controlling the compilation of MIOS.It is MIOS which will default to 4-bit mode for LCDs when the PIC is PC18F4685. So it is best to leave it alone and use 4-bit mode and not recompile MIOS.If at some point you discover that display does not like 4-bit mode (unlikely) then you can use a custom LCD driver to connect it in 8-bit mode. But there's no need to use 8-bit mode until you have a problem with 4-bit mode.
TK. Posted August 24, 2007 Posted August 24, 2007 Sidenote: there isn't really an performance impact when using 4bit modeBest Regards, Thorsten.
mat_s Posted August 24, 2007 Author Posted August 24, 2007 oh, i was not really worried about performance. i was just being a bit lazy and wondered if i could simplify the spaghettis inside the box. :)
Therezin Posted August 29, 2007 Posted August 29, 2007 Type: Yellow STNNot a PLED, just your standard Super-Twisted Nematic LCD.
mat_s Posted August 30, 2007 Author Posted August 30, 2007 Not a PLED, just your standard Super-Twisted Nematic LCD.thanks, you confirm my guess. i think i understood the difference now.cheers :)
