TK. Posted August 25, 2007 Report Share Posted August 25, 2007 As mentioned in another thread, currently no accurate .sid file player for the ASID protocol is available anymore. Totally frustrated I hacked into the unix version of sidplay2 today, and made some experiments - with the motivation to DIY a new solution. :)Sidplay2 offers a modular API for output devices, therefore it was quite easy to forward the SID register accesses to the MIDI interface. By using the ASID protocol, data is compressed in a way which ensures no dataloss so long a .sid file is played at a C64 typical update rate of 50 Hz. However, as you can hear in this sample:http://www.ucapps.de/tmp/sidplay2_via_midi_try1.mp3the driver still needs some work. Timings are too wacky. This is partly related to the way how I access the MIDI interface (/dev/snd/midi is accessed via write(), no special ALSA functions are used), but mainly because the sending routine is not synchronized to the 50 Hz update rate of the emulated C64 sound routine. Thats nothing which couldn't be improved. :)I'm planning to release the source code, but it will only run under Linux due to the way how the MIDI interface is accessed. However, is there somebody with Windows programming skills, who has the right tools for building sidplay2 under Windows, and who knows how to access the MIDI interface?Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
stryd_one Posted August 25, 2007 Report Share Posted August 25, 2007 Hehehe the last time I did any windoze programming was ...well... right before I discovered MIDIbox ;DI am quite familiar with the MMAPI (it's burned into my brain) so I may be able to help though.... Quote Link to comment Share on other sites More sharing options...
Wilba Posted August 26, 2007 Report Share Posted August 26, 2007 However, is there somebody with Windows programming skills, who has the right tools for building sidplay2 under Windows, and who knows how to access the MIDI interface?Coding C++ under Windows is my day job. ;DI'll volunteer ;D Quote Link to comment Share on other sites More sharing options...
Wilba Posted August 26, 2007 Report Share Posted August 26, 2007 btw, the link to the ASID protocol was broken a while ago, I've found it again:http://www.cs.tut.fi/~paulus/asid_protocol.txt Quote Link to comment Share on other sites More sharing options...
Wilba Posted August 26, 2007 Report Share Posted August 26, 2007 Unfortunately, sidplay2 doesn't just "build out of the box" >:(I did actually get the source package building, after finally working out where each directory of source had to go and tinkering with project files. Then decided I should build off the development source in CVS which might at least have someone else trying to build it with Visual Studio, but that didn't build immediately either...- you have to install "resid-0.16-p2.tgz" into "resid" subdirectory of root of all source. This contains changes to the official resid 0.16 which is in "resid-0.16.tar.gz" - you have to fix one compile error by replacing "log(2)" with "log(2.0)"Even with the lack of documentation on setting up a Visual Studio build environment, this was far quicker to setup than a lot of other open source projects ;D Quote Link to comment Share on other sites More sharing options...
TK. Posted August 26, 2007 Author Report Share Posted August 26, 2007 Instructions for Linux users:I compiled the CVS release - under Linux the compile order is important (don't remember which directories I compiled first, but you will find this out...). It's required to execute "bootstrap" in each directory in order to generate the "configure" file - the rest works as usual.resid is not part of the CVS for some reasons - the patched version is important. On my PC, the builder/resid-builder was not compilable due to an unknown mute() function in resid-emu.cpp - I commented this out, thereafter it worked.Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Wilba Posted August 26, 2007 Report Share Posted August 26, 2007 Yes, the missing mute() function is in the "resid-0.16-p2.tgz" package. Quote Link to comment Share on other sites More sharing options...
TK. Posted August 26, 2007 Author Report Share Posted August 26, 2007 ok, something was wrong - I applied the .patch file over the original release, maybe this was the reason.So, it should work fine when the resid-0.16-p2.tgz package is usedBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
TK. Posted August 26, 2007 Author Report Share Posted August 26, 2007 After one hour of additional work, .sid tunes are replayed much better now: :)http://www.ucapps.de/tmp/sidplay2_via_midi_try2.mp3I will clean up the code and thereafter release it as is - due to my low C++ knowledge, I don't know how to realize certain functions, e.g. passing the MIDI device via command line (currently it's hard coded), or writing the ASID routines more object oriented.Great that you want to help out, Wilba! :)Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
TK. Posted August 26, 2007 Author Report Share Posted August 26, 2007 ok, something was wrong - I applied the .patch file over the original release, maybe this was the reason.It was the reason... the Makefile which is generated from resid-0.16-p2.tgz is not complete, "make install" doesn't copy the new include files + library to /usr/local/...Workaround: generate a Makefile with the resid-0.16.tgz package and use this oneBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
TK. Posted August 26, 2007 Author Report Share Posted August 26, 2007 Source code transfered to Wilba - in the hope to have a windows version available soon :)Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
mekatron Posted October 27, 2007 Report Share Posted October 27, 2007 I have proudly finished my first midibox sid (just 1core+1sid) and wanted to play sid files. Unfortunately ASID XP didn't work on my win2k-machine and sidplayer showed the behavior that was mentioned before. but i wanted to hear definetly my favourite c64-song ;)So I did a small workaround:installed midiyoke and midiox to have virtual midiportsplayed the file in sidplayerrecorded sysex messages in midioxset the "delay after f7" down to 8msplayed the recorded sysex messagesThis method is not very effective, but it was the only way for me, to get a nice playback. Now I have a new fileformat for c64-songs: .syxI'm so happy with my fresh midibox, i never want to switch it off again ;D Quote Link to comment Share on other sites More sharing options...
TK. Posted October 27, 2007 Author Report Share Posted October 27, 2007 Clever! :)Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Smithy Posted October 28, 2007 Report Share Posted October 28, 2007 Im just wondering which version of Sidplay are ye using?In the older version of Sidplay for Win32 (Nov 7 2002), theres a really handy mixer, with the 4 sid channels.So you can mute or solo channels of your choice.After this version they removed it for reasons unknown, it was a really handy feature imo.Im pretty sure all the updates since were improvements to the sound engine.I havent used the linux version but i guess its also missing the mixer now.Do you think it would be cool to use the source from this version just to have the mixer?Or is there already away to mute channels with the Midibox itself?Just a thought. Quote Link to comment Share on other sites More sharing options...
Smithy Posted October 28, 2007 Report Share Posted October 28, 2007 I have one more question thats sort of related.Is it possible to extract the Presets/Patches from a SID file?What i mean is extract the synth patches that were used in each track.So we could convert them to the format the bankstick uses, and play the patch live.The tricky thing is that the patches change throughout the track so it might be difficult to read all patches. Quote Link to comment Share on other sites More sharing options...
mekatron Posted October 28, 2007 Report Share Posted October 28, 2007 this is maybe possible for some sounds, since you can record all messages sent to the box stop the playback at a moment and read the relevant registers from the sid -> this is the patch.but this method would only work for very basic sounds, that can be reproduced easily. Quote Link to comment Share on other sites More sharing options...
TK. Posted October 28, 2007 Author Report Share Posted October 28, 2007 It's better to trace SID register changes with a tool like SIDdump. It not only gives you the oscillator settings, but also an hint about modulations and wavetable sequences.Some infos can be found here:http://www.ucapps.de/howto_sid_wavetables_1.htmlBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
timofonic Posted January 9, 2008 Report Share Posted January 9, 2008 bump!So this will be merged into the official sidplay2? I see the development of sidplay2 is stopped since a year approximately and nobody wants to continue it in a more active way. Time for forking?What aobut using sidplay2 from Debian? It seems to have a few fixes: http://packages.debian.org/sid/sidplayI found this for mac guys: http://www.sidmusic.org/sidplay/mac/ Quote Link to comment Share on other sites More sharing options...
TK. Posted January 10, 2008 Author Report Share Posted January 10, 2008 I haven't enough C++ experiences to integrate my "MIDI hack" correctly into sidplay2All I did was to enhance the resid builder by some MIDI output routines. Normaly a seperate builder has to be created (as they did for HardSID), but my solution requires an emulation in background, so that .sid routines are able to read out the SID "random/env3" register.MIDI interface is currently hardcoded to /dev/midi - I don't know how to forward a device argument from command line to a builder.How about your programming skills? I could give you the changed builder "as-is" for a proper integration into the sidplay project.Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
timofonic Posted January 10, 2008 Report Share Posted January 10, 2008 How about your programming skills? I could give you the changed builder "as-is" for a proper integration into the sidplay project.Me? I even can't code a line of basic. I want to learn computer programming soon, but I think it's very difficult to me and not sure when being able to do something really useful.You can ask Raph, a canadian geek that does DIY hardware stuff related to retrocomputing (and a few other stuff related to microcontrollers) and maintains MikMod. Maybe you can convince him for sending a proper patch to sidplay2 developers or making some kind of fork if they don't reply.I find the idea of playing SID tunes from C64 with MIDIbox very interesting, but I have no skills. Quote Link to comment Share on other sites More sharing options...
yatagarasu Posted January 17, 2008 Report Share Posted January 17, 2008 I have proudly finished my first midibox sid (just 1core+1sid) and wanted to play sid files. Unfortunately ASID XP didn't work on my win2k-machine and sidplayer showed the behavior that was mentioned before. but i wanted to hear definetly my favourite c64-song ;)So I did a small workaround:installed midiyoke and midiox to have virtual midiportsplayed the file in sidplayerrecorded sysex messages in midioxset the "delay after f7" down to 8msplayed the recorded sysex messagesThis method is not very effective, but it was the only way for me, to get a nice playback. Now I have a new fileformat for c64-songs: .syxI'm so happy with my fresh midibox, i never want to switch it off again ;DOk, this sounds really cool. What do you mean by "played the recorded sysex messages"? How did you manage that? Quote Link to comment Share on other sites More sharing options...
yatagarasu Posted January 23, 2008 Report Share Posted January 23, 2008 Ok, I resolved my problem. Advice: Do not forward sidplay sysex messages to mbsid v1. I'm a moron. Had to reinstall MIOS. =P Quote Link to comment Share on other sites More sharing options...
yatagarasu Posted February 6, 2008 Report Share Posted February 6, 2008 When the MB goes into sidplay mode, are parameter changes turned off? Ie, can you improvise with an assignment knob while playing back a SID file? =D Quote Link to comment Share on other sites More sharing options...
TK. Posted February 8, 2008 Author Report Share Posted February 8, 2008 No, this isn't possible. The synth engines have to be disabled while the "sidplay host" controls the SIDBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
