sarnold Posted August 29, 2007 Report Posted August 29, 2007 Hi all,I just finished my compact MIDI Router. I use it for the pad-to-sample routing of my electronic drumset and/or the drumpads at my acoustic set. So I can switch songs and sounds - which neither the drum-to-midi-converter nor the sampler can do.It has 2x IIC MIDI which are connected as follows:drum-to-midi -> IN1OUT1 -> SP404 samplermidi clock (laptop) -> IN2OUT2 -> laptop (start/stop)I modified the C software so I can save banks (band or setup) and patches (songs) and start/stop the external laptop or sampler loop via drumpad, as well as synchronize to MIDI clock. The software is, like TK's, really adjusted to my setup, but if you want to take a look at it, I can send it to you or upload it.Because it needs to fit into a small roadcase together with the converter, sampler and monitor/click mixer, I built seperate TAE jacks into it - as you see on the last picture, no MIDI connector will fit in there ;)Some pics:My next project will be a combination box of an alternative edrum-converter, MB64 and MIDI router, because I just bought a Nord Modular G2 and need to go on the road with solo drums feat. G2 synthesizer. It's really fun! You can listen to my music at http://www.myspace.com/sebastianarnoldcheers,Sebastian
midiboxxer Posted August 29, 2007 Report Posted August 29, 2007 Good work, the case looks very professional.
ultra Posted August 29, 2007 Report Posted August 29, 2007 looks nice. can you tell about the case? where did you get it, how did you make the panel, etc? thanks.
sarnold Posted August 30, 2007 Author Report Posted August 30, 2007 The case is a hammond case: ( http://www.hammondmfg.com/1455V2.htm ) which I got from www.conrad.deThe panel was made by Schaeffer Apparatebau.cheers,Sebastian
Sasha Posted August 30, 2007 Report Posted August 30, 2007 Hey Sebastian, your router looks very good. Not often enough wee see professional box like yours.I`m just listening your music on myspace. It`s very good. The cover for dithering the rain reminded me of box I liked very much. :)I modified the C software so I can save banks (band or setup) and patches (songs) and start/stop the external laptop or sampler loop via drumpad, as well as synchronize to MIDI clock. The software is, like TK's, really adjusted to my setup, but if you want to take a look at it, I can send it to you or upload it.It would be nice. Better attach it to first post, so everybody can download it. Thank you in advance.
sineSurfer Posted September 22, 2007 Report Posted September 22, 2007 Hi sebastian, could you tell me the size of the standoffs you used to hold the pcb with the square switches?btw, the router looks very pro!!!
