Greetingz All,
Thank you Thorsten for all your fabulous contributions.
Herewith pictures of MIDIbox 64 with 40 knobs, 22 buttons, and encoder. Also a picture of matching eDrum module. :)
1546_MB40_1_jpgcfb9072bae2e074533a289567
1548_edrum16_6_jpg62e049ce3b4c53a08b5785
1550_edrum16_2_jpg791527703ef37b1ddf2f32
EDrum Xylophone I totally love it!! That is wicked man! Do you have a page with info on that by any chance?
Damn, I think I just acquired another project :-\
Thanks for the comments,
Do you have a page with info on that?
Not yet, but there are a few other pics posted on eDrum forum : http://www.edrum.info/forum/index.php?topic=988.0
http://www.edrum.info/forum/index.php?topic=989.0
The midi xylo consists of standard build of eDrum16 module, which connects to 14 piezos mounted under pieces of wood which are strapped down onto a wooden frame with cable ties. The bits of black stuff between the notes/pads and frame are from hacked up bits of truck tyre inner tubing. The piezos are sandwiched between layers of foam and mounted under the individual notes. The current design still exhibits some crosstalk triggering between notes, which will require messing around with more variations and layers of rubber and foam before its fully playable. Crosstalk damping is the main design challenge for building a MidiBeam/xylo. Although the eDrum module is highly responsive and functions very well, I am also interested in building a processor based on the MIDIbox64 experimental drum application, and using all 64 available inputs (if possible) to build a 5 octave MidiBeam, and possibly further develop the application specifically for handling a xylo type controller.
I will post a link here once a descriptive page is up. :)
No pictures for guests there it seems :(
Thanks mate please do!
Hey you never did tell me, if your nick is a hint that you study Zen? (If not maybe you don't know that Rinzai is the name of a Zen sect)
- oh yeah, i forget that you need to be logged in to see pics, so i repost here other pics.
Indeed, rinxai is a play on rinzai - the one hand clapping crew ;)
1552_edrum16_3_jpgb72206301a93032825fdab
1554_edrum16_4_jpg678d7c3ae26b65ca7af0f4
1556_edrum16_5_jpg904c9db38248b24dae55c4
1558_edrum16_1_jpgf7a737b69f348bde9b3457
If a tree falls in the woods and noone is there to make a wicked edrum xylophone out of it, is it still cool? ;)
Thanks for reposting the pics man!
Perhaps it would help to mount the "keys" more like vibrophone keys?
Ie drill two holes from one side to the other. One hole about 1/5th down from the top, the other about 1/5th up from the bottom.
You then mount the keys using string passed through all the keys, usually tensioned at one end.
Could cut down a lot of the crosstalk...
