Guest Dazzystar Posted May 14, 2003 Report Share Posted May 14, 2003 Hi All,I have loaded the various PCB .BRD files into Eagle Lite. Do I have to use the CAM processor or can I simply use the hide layers command under the View toolbar and print out the boards ready for press-n-peeling? The printouts looks nice and dark and are in reverse which I guess is required?Thanks. Quote Link to comment Share on other sites More sharing options...
chriss Posted May 14, 2003 Report Share Posted May 14, 2003 hijust take some overhead foil (for laser printer), disable all layers in the eagle layer menu, then enable 16 bottom, 17 pads, 18 vias, 20 dimension, 39/40 keepout and go to print and check in the printer menu if black and solid is enabled and scale factor is 1; (you don`t need to mirror because you can turn the foil.)print. chriss Quote Link to comment Share on other sites More sharing options...
Guest Dazzystar Posted May 14, 2003 Report Share Posted May 14, 2003 Hi Chriss,I guess by foil you actually meant plastic film!I'm going to be using the press-n-peel transfer system. Do I have to print in mirror image?ThanksDarren Quote Link to comment Share on other sites More sharing options...
smashtv Posted May 14, 2003 Report Share Posted May 14, 2003 I'm going to be using the press-n-peel transfer system. Do I have to print in mirror image?Yes.:)Smash Quote Link to comment Share on other sites More sharing options...
