che Posted May 15, 2003 Posted May 15, 2003 Hi,This is probably a stupid question, since I've never seen this problem on this forum before. I tried to stuff the SID-board and i came into these problems: Â ???1:On the parts list there are 3 ceramic cap 470 pF listed, on the SID-board I can only find 1.Further, is there only 1 ceramic cap 1 nF listed, Â on the SID-board I find 4.What are the correct values, or are those values exchangeable?2:Is it possible to take higher voltage for those polarised capacitors?(Excuse me for my poor English, I'm Dutch)Greets,Che
che Posted May 15, 2003 Author Posted May 15, 2003 Hi,This is probably a stupid question, since I've never seen this problem on this forum before. I tried to stuff the SID-board and i came into these problems: Â ???1:On the parts list there are 3 ceramic cap 470 pF listed, on the SID-board I can only find 1.Further, is there only 1 ceramic cap 1 nF listed, Â on the SID-board I find 4.What are the correct values, or are those values exchangeable?2:Is it possible to take higher voltage for those polarised capacitors?(Excuse me for my poor English, I'm Dutch)Greets,Che
js Posted May 15, 2003 Posted May 15, 2003 As i see it the number of three 470pF´s is right if you use the old Sid 6581 chip. If you use the never 8580 sid it´s suggested that you replace the two 470pF that´s listed as C1 & C2 with 6,8nF ones.As for the 1nF I think there´s a mistake in the parts list. When I bought the stuff for my sid I was one short of these, it seems like the parts list is missing one. How you find four 1nF´s I don´t know I only see two. Good luck getting this thing to work, it´s brilliant!!!js
che Posted May 15, 2003 Author Posted May 15, 2003 Thanx for the reply,Ok, I found the 470 pf caps on the schematic (C1 and C2), but on the eagle board layout they are valued 1 nf. I assume that the values on the schematic are the correct ones, So that problem is tackled.
gillesdeshays Posted May 15, 2003 Posted May 15, 2003 oh oh ....I mount 2 * 1nF for C1/C2 ......oopppsss ...That's maybe for this reason that my SID is really hot !???Gilles
d2k Posted May 15, 2003 Posted May 15, 2003 heh, dont worry about it - i also used 2 x 1nf caps on my first SID box (still workin) i think it just made the filters sound a tad different, i sinced changed them to the recommended ones for the 6580 just in case ;)...the SID does run hot - that's normal ;p whack a heatsink on if u really wanna, i havnt bothered tho...best...Dan
gillesdeshays Posted May 16, 2003 Posted May 16, 2003 And you prefer which value for the sound ?Gilles
js Posted May 16, 2003 Posted May 16, 2003 I tried with 1 nF ones instead of the 6.8 for my 8085 to test if the filters were better. For me at least that wasn´t better. I was hoping that the cutoff would be spread a bit more on the slider, but it was almost the other way arround. (i have to move the fader alot to the left before the sound change.) I was thinking to try above 6.8 if im able to get my hands on them. If I do i´ll keep you posted.js
