shmuu102 Posted November 21, 2007 Report Share Posted November 21, 2007 Iv been searching around the forums , trying to find out if theres an easy way to remap the DIN pins. for a mb64e (which pins are encoders, buttons, or meta events)..is there a way to do this in the mb64e editor, or do i have to recompile the code?it just seems like im missing something really basic..thanks in advance Quote Link to comment Share on other sites More sharing options...
TK. Posted November 21, 2007 Report Share Posted November 21, 2007 Hi,remapping has to be done in main.asm and mios_tables.incThereafter recompile the code as described here: http://www.ucapps.de/howto_tools_mpasm.htmlBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
shmuu102 Posted November 28, 2007 Author Report Share Posted November 28, 2007 Thanks for the help previously.... it was easier to edit, and recompile than i remember. (Im building a cubase controller with 2 cores, one 64, and one 64e... the 64e is the one giving me problems.)but, im still having problems with a few of the DIN inputs... some just seem to be dead, or unused.I would like to keep the menu keys, but get rid of all the other special function keys that are set by default. I make some changes in main.asm (set some options to "0") but it didnt seem to make a difference.I have assigned 36 encoders and 50 buttons. I am using 4 din modules, but the last 4 encoders dont seem to function. I will have to paste the code edits from home.thanks in advance for any advice./ Quote Link to comment Share on other sites More sharing options...
TK. Posted November 28, 2007 Report Share Posted November 28, 2007 Hi,for 36 encoders, you probably have to set the DEFAULT_ENCODER_GROUP_WIDTH setting to 64, as this is the next 2^n value after 32Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
shmuu102 Posted November 29, 2007 Author Report Share Posted November 29, 2007 thanks for the prompt response...I do believe i did chance it to 64here is a link to a copy of my main.asm and mios_tables.inchttp://www.dimmworks.com/diy/main.asmhttp://www.dimmworks.com/diy/mios_tables.incthanks for all your help... you rock.. Quote Link to comment Share on other sites More sharing options...
smashtv Posted November 29, 2007 Report Share Posted November 29, 2007 I merged these threads for clarity, this is not a help desk......In other words it's much harder to help when the same issues are spread across multiple posts.Best RegardsSmashTV Quote Link to comment Share on other sites More sharing options...
TK. Posted December 2, 2007 Report Share Posted December 2, 2007 I think that the last encoder assignments won't work this way: ;; encoders 33-48 ENC_ENTRY 13, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 33 ENC_ENTRY 13, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 34 ENC_ENTRY 13, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 35 ENC_ENTRY 13, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 36 ENC_ENTRY 13, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 37 ENC_ENTRY 13, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 38[/code]It isn't explicitely mentioned, but double-assignments are not allowed.Instead, you have to assign the last two encoders to individual pin groups, e.g. 14,0 (for SR14, pin 0 and 1) and 14,2 (for SR14, pin 2 and 3)Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
