cimo Posted December 20, 2007 Report Share Posted December 20, 2007 halloi really can t get the pic burner to work.the 100R test goes righti am using 2X 9 volts batteries to supply the whole thingmy compy is a 1000Mhz PIIIthe red led is always oni can only trig the data led from within the applicationi am using cheap 7414 (no hc) can that be a problem?any idea?simone Quote Link to comment Share on other sites More sharing options...
TK. Posted December 20, 2007 Report Share Posted December 20, 2007 I remember that somebody else reported such an issue with 7414 (without HC) some time ago, so I think that this could cause the problem. 74HC14 is more tolerant against CMOS drivers, and your PC board is probably stuffed with such ones.Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
cimo Posted December 20, 2007 Author Report Share Posted December 20, 2007 ..looking forward to desolder 7414s :( , i am a guru now i don t use IC sockets ::) i will let you know how it goes tomorrow i am off for some fish bbq now... Quote Link to comment Share on other sites More sharing options...
bugfight Posted December 20, 2007 Report Share Posted December 20, 2007 ..looking forward to desolder 7414s :( , i am a guru now i don t use IC sockets ::)...cut those pins off first or risk lifting pads...ok, you already knew that but maybe n00b didn't.congrats on your new guru status, now fix all my stuff for me *whack* Quote Link to comment Share on other sites More sharing options...
cimo Posted December 23, 2007 Author Report Share Posted December 23, 2007 i got some 74HC14 (no HCT) but the burner doesn t work.When i plug the lpt cable the red led lights up, is this anormal?When i plug the lpt cable without the supply connected, the red and green led light up but not so brightly as with the supply.This doesn t happen all the times ! it happens "sometime".???simone Quote Link to comment Share on other sites More sharing options...
