djiceman Posted January 5, 2008 Posted January 5, 2008 I came across a prioject called midi-nator, it uses a 18f2455.Though the usb to midi pic module on the midibox site says that all 18F devices are useless for midi???Can anyone help with this?I have the source code for the midi-nator project, maybe that will help to complete the midibox usb to midi?I need to get the midi to usb as laptops dont have game ports and the commercial usb to midi units are very expensive in south africa.just another thought, will this work>>>midibox to com(rs232) then a rs232 to usb?so you end up having the midibox going to usb via the serial port?thanks
TK. Posted January 5, 2008 Posted January 5, 2008 This topic pops up regulary, but I can only say: in distance to other people, I'm not willing to release a buggy solution.MIDI-Nator: was affected by the EUSART bug as well, this has been confirmed by Robert. Meanwhile the silicon issue has been fixed by Microchip, and if you've luck, you will be able to purchase a working chip (rev5) and won't receive an old stock part. But there are additional issues, e.g. instable SysEx transfers under Windows, which has been solved by commercial companies by developing their own MIDI driver. Such drivers are protected, so that it isn't possible to adapt the PIC firmware.For my own interest I tested the firmware with a shiny new PIC18F4550 rev.5 under Mac OS today. Unfortunately it doesn't work better as under Windows - in distance: just send some MIDI notes, thereafter a SysEx string - this will hang up the MIDI Out port (to USB experts: the OUT endpoint doesn't receive any message anymore, BDn_STAT_UOWN is permanently set, no USB error is reported). Reconnect the interface, start with some SysEx messages: works. Send some notes: no MIDI out data anymore! MIDI In port is working better, but not perfectly (data loss on higher data rates)Thereafter I tried Mac OS with Cypress based MBHP_USB instead: works perfectly! Even better than under Windows (multiclient capability! :-))Thereafter I tried Robert's MIDI-nator firmware: same effect as with MBHP_USB_PICThereafter I searched in the internet for other firmwares and found Synthex's firmware for the Megadrum project: same effect as with MBHP_USB_PICFrustrating! RS232 solution: yes, some guys already tried this and know how to set it up - google for "ftdi usb midi"Best Regards, Thorsten.
Ashiman Posted January 5, 2008 Posted January 5, 2008 my newb question:does it make sense to drive the usb receiver in async fashion and regenarete clock after its out of the box? In audio thats sensible to do with usb...
rinXai Posted January 6, 2008 Posted January 6, 2008 Hi djiceman - a local supplier for cheap rs232/usb converter cable (R114) :http://www.sybaritic.co.za/store/product_info.php?products_id=3899also www.soundz.co.za does midi/usb converter cables for under R500. ;)
Ashiman Posted January 20, 2008 Posted January 20, 2008 to quote myself:does it make sense to drive the usb receiver in async fashion and regenarete clock after its out of the box? In audio thats sensible to do with usb...would it make sense to transmit midi over OSC thru USB in async fashion ? :)
