hallo
it sounds easy but i need help:
4 buttons with leds
1 pot (pedal)
MB64
a)do the usual tweaking on main.asm
b)in mb64_meta.inc change meta event 00
MB64_META_Handler_00
   ;; set global channel to the second byte of a F0 xx meta event
   movff MB64_GLOBAL_CHANNEL, MIDI_EVNT1
   return
tx TK c) change mb64_presets.inc
MB64_Presets_OffsetButtons
	;; DIN/DOUT group 0
	BUTTON_ENTRY 0xf0, 0x01, 0x7f, 0x00
	BUTTON_ENTRY 0xf0, 0x02, 0x7f, 0x00
	BUTTON_ENTRY 0xf0, 0x03, 0x7f, 0x00
	BUTTON_ENTRY 0xf0, 0x04, 0x7f, 0x00
	BUTTON_ENTRY 0x94, 0x30, 0x7f, 0x00
	BUTTON_ENTRY 0x95, 0x30, 0x7f, 0x00
	BUTTON_ENTRY 0x96, 0x30, 0x7f, 0x00
	BUTTON_ENTRY 0x97, 0x30, 0x7f, 0x00
>>in main.asm i set pots number to 1 and buttons to 4
>>i just need to change the cc/channel sent by the pot with the 4 buttons so also a "group" switch would be ok, but groups are only on MB64E not in MB64
-am i right?
i need MB64 for the soft take over, it s a pedal for guitar
considering a possible development, is it possible to assign the midi channel via meta event to 2 buttons (next/previous) and assign eg 8 leds to monitor in which global channel the box is?
thanks
simone
.. that sounds like "c mon simone learn some C it s just about time.."
c is easy, it's not like you need to get an "A" in it...
*whack*
